Old 06-17-2025, 05:39 AM   #1
Boxhead
Default Reduction box
Hi All,
Wondering if anyone has seen a reduction box like this?
Cheers
C
Sent from my SM-F956B using Tapatalk
Boxhead is offline   Reply With Quote
Old 06-17-2025, 06:25 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Reduction box
Probably Australian creation.
Old 06-17-2025, 06:54 AM   #3
deuce lover
deuce lover's Avatar
No picture ?
Old 06-17-2025, 07:20 AM   #4
pistonbroke
Is it a reduction or an overdrive? Tim
Old 06-17-2025, 07:56 PM   #5
TomC750
TomC750's Avatar
Be easy enough to tell by turning input shaft.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 06-18-2025, 07:41 PM   #6
Boxhead
Hi All,
Definitely a reduction box, 2:1. Which would mean very low if you were in first gear, the reduction box engaged and then the differential in low as well!
First one I've seen, i was hoping it was an overdrive!
Cheers
Corey
Old 06-18-2025, 08:05 PM   #7
fordyford
fordyford's Avatar
Looks like you could turn it around and make it overdrive?????
fordyford is offline   Reply With Quote
