Old 04-22-2025, 02:37 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Manifold Vacuum
For your info, I just finished connecting a vacuum gauge to the windshield wiper fitting on the firewall of my Victoria. Idling at 160F, the gauge reads 22 InHG which is an excellent reading. The engine is a Model B with a 6:1 compression cylinder head, stock Model B camshaft and a Model A Zenith 2 carburetor. This engine has approximately 2500 miles on it since it was completely rebuilt. The vacuum gauge is a 2" diameter unit made by Auto Gage and it will stay in the car.
I do not use the stock windshield wiper, and this year the stock wiper motor will be replaced by an electric unit.
Bob Bidonde
Old 04-22-2025, 04:43 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Manifold Vacuum
Indeed 22 inches of Hg is good. Air pressure at sea level is 29.92 inches of Hg. That is a good gauge to keep in the car. You can use it to diagnose troubles and feather the engine for good mileage.
Old 04-22-2025, 06:19 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Caution! This is where the last discussion on Vacuum gauges ended...
https://www.fordbarn.com/forum/showt...+Minder&page=2
Old 04-22-2025, 06:35 PM   #4
Gene F
Gene F's Avatar
Electric wipers are the way to go. Not just on an A, but even later cars.
Old 04-22-2025, 07:49 PM   #5
Joe K
Joe K's Avatar
When Dad owned his 29 RPU, the car had a vacuum wiper.
He was 18-20 at the time and had discovered "smoking." He would regale his friend on how his truck was "smoking hot" and using the rubber vacuum hose on the mouth end of the cigarette (no filter) and it would "burn it right down" in about 20 seconds.
"Waste of a good cigarette" his friend's reply.
Joe K
Shudda kept the horse.
Old 04-22-2025, 08:23 PM   #6
Y-Blockhead
My '55 Ford Ranchwagon had vacuum wipers. What a PITA with the "dual action" fuel pump to provide enough vacuum on acceleration. It has electric now
Old 04-23-2025, 07:04 AM   #7
nkaminar
nkaminar's Avatar
The vacuum windshield wipers are a form of vacuum gauge. Step on the gas and they slow down or stop. Let up on the throttle going down a grade and they fly back and forth at an impossible speed. (Early variable speed wipers?). I used to enjoy using them on a car that I had years ago. I was intrigued by the technology.
Old 04-24-2025, 07:05 AM   #8
noboD
A friend owned a '24 Buick that had been Professionally rebuilt but never ran correctly for many years. He bought it and wanted to fix it. I put a vacuum gauge on it and it showed retarded cam timing. He was positive I was wrong as he knew the rebuilder. Months later he pulled the cover of and HE discovered the cam was off 3 teeth. I am a believer in what the gauge says.
noboD is offline   Reply With Quote
Old 04-24-2025, 09:06 AM   #9
Bob Bidonde
Yesterday I made a 24 mile run cruising at 50 MPH. While cruising at a steady speed, the manifold vacuum was steady at about 17 InHG. The slightest change in the throttle drops the manifold vacuum near zero. This sensitivity is due to the small (undersized) CFM of the Zenith carburetor. That is to say, it takes a large throttle change to accelerate the Model "A".
Bob Bidonde
