Old 04-26-2025, 09:36 AM   #1
RGC1
Default Clutch disc choice ?
Hi
Just looking to purchase a new clutch disc for my 34 fordor, which has a 40 flathead going in so it is a 9 inch. Is there much difference from one over the other in brand, finish, etc., or will just about any on the market do the trick ?
Thanks
RGC1 is offline   Reply With Quote
Old 04-26-2025, 11:56 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Clutch disc choice ?
The market is likely limited to no more than one or two sources on these as far as manufacturing is concerned. It's a niche market so the market is not a big one. The later 9N, 2N, & 8N tractors use them so there are still a lot of them in common use. The thing to look out for is the way the torque springs are mounted in the disc. Some are well made and some have windows that are a little too open and those tend to have spring problems. There are other threads on these if a person can do a search. Some have photos.
Old 04-26-2025, 03:45 PM   #3
leon bee
Buy it from one of our trusted sources.
leon bee is offline   Reply With Quote
Old 04-26-2025, 03:45 PM   #4
RGC1
Perfect thanks for the information, I will do a search, rather end up with the right one the first time if possible.
Thanks
Old 04-26-2025, 03:47 PM   #5
RGC1
Sorry some what new to the site , if I do some searching I can find the trusted or suggested sources ? Thx
Old 04-26-2025, 04:42 PM   #6
big deuce
big deuce's Avatar
Mac VanPelt sales. Best around.
big deuce is offline   Reply With Quote
Old 04-26-2025, 04:42 PM   #7
Als48
Speedway motors or Dennis Carpenter Ford parts are both good sources.
Als48 is offline   Reply With Quote
Old 04-26-2025, 04:51 PM   #8
Tim Ayers
This.
Old 04-26-2025, 05:09 PM   #9
big deuce
big deuce's Avatar
My last order with Dennis Carpenter was a disaster of offshore garbage...never again
Old 04-26-2025, 06:03 PM   #10
leon bee
Van Pelt, Third Gen in Tennessee, C and G in California. Many others, sorry for whomever I forget.
Old 04-26-2025, 06:06 PM   #11
tubman
tubman's Avatar
There's a thread on here about approved vendors. I tried to find it, but with no luck. Maybe someone knows where it is.
Old 04-26-2025, 06:28 PM   #12
alchemy
alchemy's Avatar
I’ve bought transmission parts from Mac VanPelt and have always been happy. But when you buy his transmission rebuild instruction book, you will be even happier.
alchemy is offline   Reply With Quote
Old 04-26-2025, 07:06 PM   #13
Tim Ayers
Word. Buy his book for sure.
Old 04-27-2025, 09:01 AM   #14
RGC1
Thanks everybody
I have been dealing with Mac at Vanpelts they have been great to deal with at the time did not have a nine inch clutch assembly I have since found a old nos clutch just no disc I will phone van pelts back in case he has the disc in stock. Thx
Old 04-27-2025, 12:03 PM   #15
glennpm
glennpm's Avatar
This is the thread I remember.
https://www.fordbarn.com/forum/showt...t=good+vendors
Old 04-27-2025, 01:06 PM   #16
kurt v
Take a look at 9" clutch 1986 T-bird 4cyl turbo engine 1 1/16x 10 spline, i have this in my notes , wrote it down from this form i think.
kurt v is offline   Reply With Quote
Old 04-27-2025, 02:12 PM   #17
tubman
tubman's Avatar
Originally Posted by glennpm View Post
And that thread points to this one : https://www.fordbarn.com/forum/showthread.php?t=269580
Old 04-28-2025, 01:22 PM   #18
51504bat
51504bat's Avatar
Check with Kentucky Clutch
https://kyclutch.com/
Old 04-28-2025, 03:42 PM   #19
Bruce_MO
I bought a clutch disk from Thirdgen a while ago, and it was surprisingly sloppy on the splines of the input shaft. I tried it on 2-3 other shafts I had and it wobbled maybe 3/4” or more at the outer edge of the disk. I called Michael and he said he had two suppliers and he sent me one from his other supplier. It fit a lot better, and he told me to pitch the other. So whatever you end up with, try it on your input shaft see how it fits. I don’t know that there’s a spec for looseness, but I’d never seen one with that much slop.
Now that the car is together and running, it’s the nicest clutch I’ve ever had on an old Ford.
Bruce_MO is online now   Reply With Quote
Old 04-28-2025, 09:04 PM   #20
RGC1
Thanks for all the info , helps a lot , that is the problem with some of this aftermarket stuff , some good, some not so good. Thanks again I will go through the approved list also, nice to deal with people that know. Thanks
