Old 04-18-2025, 06:49 AM   #1
Steve in Tampa
Default a and b inter splash pan difference
Can anyone post pictures of the oil splash pan of the model A and the B. The B inter splash pan is suppose to sit lower in the oil pan . I would to like to see pictures of the side of both to tell the difference. Thanks, steve
Steve in Tampa is offline   Reply With Quote
Old 04-18-2025, 10:08 AM   #2
Joe K
Joe K's Avatar
Default Re: a and b inter splash pan difference
My Model A engines show the "bulge" that holds the pan 3" below the top of the flange.
My Gordon-Smith Model B engine shows the bulge also at 3"
Not to say that the tray pressing (inside) might not be pressed to make the tray "shallower" or "deeper" when installed. Or even a difference in the tray "dips" themselves.
The Model B oil pan had welded "extension" which mated with the lower flywheel housing. A bit different than the Model A. Many in converting a Model B engine for Model A use will "cut off" this extension, usually leaving evidence of the modification before painting. I'm not seeing this on the GS Air compressor. It may well be a Model A pan, which would be consistent with typical GS production from "parts."
This Model B pan (Ebay) seems to have seen better days.
Joe K
Shudda kept the horse.
Old 04-18-2025, 10:49 AM   #3
Flathead
Flathead's Avatar
The bulge on the Model A dipper tray flange was raised to allow the tray to sit slightly lower in the pan. The pan was not changed. If you look at the edge of the original design dipper tray the bulge is centered on the edge flange, the bulge is moved up near the top edge of the flange for the lowered tray. There was also a shield added to cover the oil pump with the new tray.
Flathead is offline   Reply With Quote
Old 04-18-2025, 11:07 AM   #4
Joe K
Joe K's Avatar
Good catch!
Ford Service Bulletins page 576 for both oil pump shield AND the change at the dipper tray pressing. Dipper tray lowered 1/8" thereby.
Late in the Model A designation - and would have been applied to Model B.
Joe K
Old 04-18-2025, 11:49 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
then holes were added— several versions
Old 04-18-2025, 05:22 PM   #6
Joe K
Joe K's Avatar
There apparently were MANY modifications made to the shelf over time.
A posting I discovered about a "bolted in" splash tray is but one.
https://www.fordbarn.com/forum/showt...ly+splash+tray
Joe K
Old 04-18-2025, 09:51 PM   #7
Keith True
Keith True's Avatar
The reason guys cut the back off the B pan to use it in an A was because the rear main bearing cap has a larger radius than the A.The A pan won't fit over the B rear main cap.
Old 04-19-2025, 08:53 AM   #8
Steve in Tampa
I need pictures of the side of the dipper tray to see the difference in the bulges. steve
Old 04-19-2025, 10:25 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
it’s in the service bulletins,with more of the evolution in later ones
