Old 03-18-2025, 03:39 PM   #1
Masot
Default 10" diaphragm clutch adaptation
Hi guys.
This is my adaptation for a diaphragm clutch. before 11" now 10"
I made an adapter to center the diaphragm.
centering device for screw holes
change of centering by bearing
new thrust bearing
Kit
bearing SKF N1444SA
I have driven and run well
Masot is offline   Reply With Quote
Old 03-18-2025, 08:02 PM   #2
Bullerman
Default Re: 10" diaphragm clutch adaptation
Looks nice. I am having clutch trouble myself and don't know what to do. I had the pressure plate( original three finger style from Shoe Box Central) clutch disk, throw out bearing and pilot bearing. This is on a 50 model. I had bad clutch shudder before and after having everything replaced. Wish I would have bought. Billett flywheel and diaphragm pressure plate.
Looks nice what you made.
Bullerman is offline   Reply With Quote
Old 03-19-2025, 09:14 AM   #3
tetanus
whats going on with that throwout bearing and clutch fork?
tetanus is offline   Reply With Quote
Old 03-19-2025, 09:41 AM   #4
alchemy
alchemy's Avatar
What is the purpose of the new throwout bearing guide? Did you need a different bearing, or a different offset?
alchemy is offline   Reply With Quote
Old 03-19-2025, 10:12 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
Did you have the PP and flywheel balanced afterwards? I would sure recommend it.
Old 03-19-2025, 10:40 AM   #6
Tim Brown
Tim Brown's Avatar
What transmission is that?
Tim Brown is offline   Reply With Quote
Old 03-19-2025, 01:36 PM   #7
GB SISSON
GB SISSON's Avatar
Gotta love the adaptability of the Ford hogshead.
Old 03-20-2025, 03:45 PM   #8
slowforty
slowforty's Avatar
What is the advantage of a diaphragm clutch. I have an 11 inch Clutch in my 40 with no issues. Are the majority of V-8 owners short ,98 lb people.
slowforty is offline   Reply With Quote
Old 03-25-2025, 06:11 AM   #9
Ron_r1959
Ron_r1959's Avatar
a 11" centrifugal/ original type clutch is fine as long as you don't try and drag with it lol, they have a nasty tendency to not want to release at RPMs above 4000, it can get hard on the tranny. That would be one reason I could think of.
Ron_r1959 is offline   Reply With Quote
Old 03-25-2025, 08:07 AM   #10
Bored&Stroked
Diaphragm clutches tend to take less pedal pressure to actuate than long clutches. This is especially true in higher performance applications running at higher RPMs.
