Old 02-17-2025, 12:38 PM   #1
Wick
Wick's Avatar
Default Water jacket cleaning part 2
Taped all the holes off, hooked up 5hp. Shop vac to water inlet. Remove tape off of 1 hole, scratch around with a screwdriver. Afterwards I ran the magnet into each hole. Results just a tiny amount of debris cam out.
Inside of shop vac tells the story.
Wick is offline   Reply With Quote
Old 02-17-2025, 12:51 PM   #2
Jim Brierley
Default Re: Water jacket cleaning part 2
I've attached a piece of speedometer cable to my drill motor, turned it CCW, down thru the water openings in the block, and with the block downside up, rooted around in the block. Gravity does the rest.
Old 02-17-2025, 12:52 PM   #3
Fullraceflathead
Fullraceflathead's Avatar
So much better to have in the shop vac instead of plugging up the tubes in the top of the radiator!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-17-2025, 09:38 PM   #4
Bigsnapper43
I use a piece of lawn mower control conduit with a hand drill. Be hind cyl. 4 is the area to work on heavily. Lots of air then water and air. You would be amased the pile that comes out!!!
Bigsnapper43 is online now   Reply With Quote
Old 02-19-2025, 09:58 AM   #5
Chris in WNC
Chris in WNC's Avatar
when I cleaned out the water jackets of my unrestored '31 Coupe several years ago I got a peanut butter jar full of scale.......
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 02-19-2025, 03:23 PM   #6
Bruce of MN
Bruce of MN's Avatar
After driving for a rew days with vinegar in the radiator, I got this mess:
Old 02-19-2025, 04:30 PM   #7
Chris Haynes
Chris Haynes's Avatar
A much easier way to do it without tools is using RUST911. Drain the cooling system and refill with rust 911. Leave it in fir 24 hours. You can drive the car with the RUST911 in it. Drain and you will notice that the clear RUST911 is now black. Repeat the procedure till it drains clear. The rust911 will dissolve all the rust from the cooling system. It even dissolves the rust flakes in the radiator. https://www.amazon.com/Rust911-16-ga...59&sr=8-1&th=1
1921 Runabout
1930 Tudor
Early 1930 AA
