Does the switch part of the harness need to be set a certain way so that the prongs on the column line up correctly, can't seem to get the switch right,won't look straight down on the steering wheel ?
thanks kurt |
Maybe the spider on the bottom of the horn rod needs to be turned 90 degrees.
thanks |
