Old 12-17-2024, 12:10 PM   #1
flathead4rd
flathead4rd's Avatar
Default oil pan questions. 49-53 8-CM
The main question is about the front seal on the crank shaft. it's a one piece seal slide on type has a small hole on one side. I assume the hole faces toward the engine. Second question. The seal appears to be set into the block and pan with some type of silicone in both the block and pan area. There are no rope type seals in the front, just the rear of the pan. Any ideas what type of sealer to use. Second question: Do you use Permatex #2 on both sides of the pan rail gaskets. Thanks in advance for all replies.
flathead4rd is offline   Reply With Quote
Old 12-18-2024, 02:10 PM   #2
tubman
tubman's Avatar
Default Re: oil pan questions. 49-53 8-CM
When I built my last engine, I had one of those one-piece seals in hand. When I realized what was need to use it, I tossed it and went back to a traditional rope seal. No leaks so far.
Old 12-18-2024, 02:23 PM   #3
69a
As far as the pan gasket goes, I use Hylomar Blue, it's a non setting sealant. Permatex 2 sounds similar. Just a light coating on the pan rail, put the gaskets on, then a light coating on gaskets and put the pan on. Don't over tighten the pan bolts.
69a is offline   Reply With Quote
Old 12-18-2024, 03:23 PM   #4
flathead4rd
This one has been on my engine for several years and never leaked a drop. What was needed to use it? Just curious as I never had any problems with it. Thanks for your quick reply.
Old 12-18-2024, 03:25 PM   #5
flathead4rd
Thanks 69a.
Old 12-18-2024, 08:02 PM   #6
rotorwrench
rotorwrench's Avatar
Both my 51s have the rope seal. If you have to pull the pan but know the condition of the upper block mounted part of the rope seal then it may work by just replacing the bottom half. I've done it before with good results but I trim the ends to allow it to stand proud a little just to help pack it in there.
Old 12-26-2024, 02:14 PM   #7
flathead4rd
Could you be more specific about your problem with using the one piece seal? What was needed to use it? Thanks, John.
Old 12-26-2024, 03:59 PM   #8
tubman
tubman's Avatar
This was a long time ago, but as I remember, the one I had didn't fit neatly into the space provided; the instructions said to fill it with silicone sealer for support. That didn't seem right, so I went with the conventional seal and haven't regretted it. It also needed something called a "Redi-Sleeve". It didn't come with the seal. The whole deal seemed kind of shoddy to me. I do not know if the current setups are improved or not. Initially, it seemed like a good idea.
Old 12-27-2024, 01:36 PM   #9
flathead4rd
Thanks for he quick reply. It's was very helpful.
