Old 12-17-2024, 08:03 PM   #1
19Fordy
19Fordy's Avatar
Default Temperature sender question -`1940
Does the stock 1940 Ford 85 HP engine have only one temperature sender unit, Part Number 991-10884, and it's located in the pass. side cylinder head?
I am thinking that the 1940 85 HP Driver Side Cylinder head DID NOT have a temperature sender. TRUE or FALSE?
What year did Ford start installing temp. sending unit in Pass. Side Head?
Thanks, Jim
Old 12-18-2024, 07:15 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Temperature sender question -`1940
For 40 the left (drivers) side head had had the single electrical terminal temperature sender. The right side head had provision for the hot water heater valve and was plugged if the hot air or no heater was installed.
Old 12-20-2024, 02:30 PM   #3
joel
joel's Avatar
Thanks, Jim
I think it started with the 8ba. The pass side was the sender for the instrument panel but it went through the drivers side "switch", which above a certain water temp. would open and I think the guage would read all the way to the left.
On my truck (59A) ,I installed a temp sensor in each head. I ran a wire from each to a DPDT switch so I could switch back and forth and read either half of the engine. Many people with FH s have done this.
joel is offline   Reply With Quote
Old 12-20-2024, 03:22 PM   #4
19Fordy
19Fordy's Avatar
Joel: Am I correct in assuming that (when using a single core radiator) if you only install a single pole temp. sender in only the driver side head of an 8BA your gauge will record the correct water temp. In this case, no temp. sender will be installed in the pass. side head.
Thanks, Jim
Old 12-20-2024, 03:49 PM   #5
tubman
tubman's Avatar
Back in my snowmobiling days, I thought these were cool.
Old 12-20-2024, 04:20 PM   #6
JayChicago
JayChicago's Avatar
Thanks, Jim
Yes.
Old 12-21-2024, 09:25 AM   #7
joel
joel's Avatar
Thanks, Jim
Yes, it should. If you assume the engine has 2 identical water pumps, then the flow should be equal and the single core or split core shouldn't matter because the top and bottom tanks allow some mixing as they aren't divided. There are a lot of factors that could effect flow through each side of the block, but I think the pumps are the main factor. That's why I want to be able to see the temperature out of each head. I had my pumps rebuilt by Skip Haney and the the temp. out of each side is within 5-8 deg. of being the same. The temp. sensors are within <5 deg of each other in a pan of hot water on the kitchen stove.
Old 12-22-2024, 04:00 PM   #8
19Fordy
19Fordy's Avatar
Joel, Good points. Both my 8RT pumps were rebuilt by Mr. Haney so I am pretty sure they are the same.
