Old 08-04-2025, 12:37 PM   #1
jdjj
Default 1935 horn wiring
Does the horn only have one wire and to which terminal does it go? The one with the white dot or other one? I assume there is no ground wire since its grounded when horn button pushed? The bolt that holds horn on goes thru fender and has the rubber head light pad underneath, but does this ground any way since bolt contacts metal underneath fender? I have a 1934 sedan with terminals a little different, but it has a ground wire on one of the terminals. ??
jdjj is offline   Reply With Quote
Old 08-04-2025, 01:03 PM   #2
jdjj
Default Re: 1935 horn wiring
couldn't get pic to load
Old 08-04-2025, 01:49 PM   #3
petehoovie
petehoovie's Avatar
Old 08-04-2025, 10:56 PM   #4
Don Rogers
Don Rogers's Avatar
Here are two images. One shows the 2 terminals on the horn and the correct wires that goes into them. The second shows the correct horn wire harness with the yellow wire and the blue wire with yellow tracer
Don Rogers is offline   Reply With Quote
Old 08-05-2025, 12:23 AM   #5
petehoovie
petehoovie's Avatar
Old 08-05-2025, 04:36 PM   #6
jdjj
tks petehoovie for the pic it's just like mine i was going to wire it to the two screws since i didnt have original wiring. Do you see any issues with that? Also which screw would be hot side? Thanks for your help.
Old 08-05-2025, 06:13 PM   #7
Bob C
I don't see any screws for the wires. This is a Model A horn but the wire hook up the same way.
Old 08-05-2025, 06:18 PM   #8
petehoovie
petehoovie's Avatar
Old 08-07-2025, 06:01 PM   #9
danliveshere
danliveshere's Avatar
Jdjj the wires slip into the terminals in here. You may need a pointed nose pliers to push them in. I soldered mine into the horns with no bullet end connectors.
danliveshere is online now   Reply With Quote
Old 08-07-2025, 06:09 PM   #10
petehoovie
petehoovie's Avatar
Old 08-08-2025, 12:53 PM   #11
jdjj
tks I made some" bullets" out of wire connectors should work
