Old 10-30-2024, 05:08 PM   #1
quickchange
quickchange's Avatar
Default Early front hub
Question is the early 1928 (AR) front hub same as the later ones , I know the drum is different. Friend has a stuffed one & trying to fix by replacement one , So will the (AR) early 28 drum fit & work on the later Model A hub ,
Thanks Derek in NZ
quickchange is offline   Reply With Quote
Old 10-31-2024, 09:02 AM   #2
180 a
Default Re: Early front hub
No the AR hub is different , the AR is flat on the outer surface and later one
has a dish to it. also the back side does not the heft around the race the later one has
180 a is offline   Reply With Quote
