Old 08-23-2024, 07:17 PM   #1
coolcoupe
coolcoupe's Avatar
Default Shocks
Should the rear axle be on stands to check fluid level on lever shocks ?
coolcoupe is offline   Reply With Quote
Old 08-23-2024, 07:44 PM   #2
Kube
Kube's Avatar
Default Re: Shocks
Level ground is good enough.
Old 08-23-2024, 08:51 PM   #3
coolcoupe
coolcoupe's Avatar
Default Re: Shocks
Thanks Kube
Old 08-24-2024, 12:44 AM   #4
ford38v8
ford38v8's Avatar
Default Re: Shocks
Like the transmission and differential, the shocks are to be filled only to the level of the inspection hole on the side. This procedure requires the car to be sitting level.
Alan
Old 08-24-2024, 07:18 PM   #5
coolcoupe
coolcoupe's Avatar
Default Re: Shocks
I got her done today,both were down 3 ounces,I feel better now.
Old 08-24-2024, 07:21 PM   #6
Kube
Kube's Avatar
Default Re: Shocks
Three ounces? My gosh, they were empty!
Old 08-25-2024, 07:21 PM   #7
coolcoupe
coolcoupe's Avatar
Default Re: Shocks
Sorry Kube, I meant the tranny/rear end was down 3 ounces.
Old 08-26-2024, 05:34 PM   #8
Kube
Kube's Avatar
Default Re: Shocks
You scared me at first!
Old 08-26-2024, 06:38 PM   #9
coolcoupe
coolcoupe's Avatar
Default Re: Shocks
While I got your attention, do I fill the shocks to the top or leave some room at the top ?
Old 08-26-2024, 06:42 PM   #10
Kube
Kube's Avatar
Default Re: Shocks
Fill em up...
Old 08-26-2024, 08:29 PM   #11
coolcoupe
coolcoupe's Avatar
Default Re: Shocks
I've got everything ATF to hydraulic oil that goes into them, what's your take on that ?
Old 08-26-2024, 08:47 PM   #12
Clem Clement
Clem Clement's Avatar
Default Re: Shocks
In my '39 pickup, I drained the shocks by their removal, flushed them and refilled with hydraulic oil (I believe.) I marked the mid line of the adj with yellow paint and set them in that position (They were all over the marking scale.
