Old 08-24-2024, 04:54 AM   #1
Brian
Brian's Avatar
Default spark plug recommendation
I'm running some early Edelbrock heads, looks like sparkplug reach is about 1/2". regular H10's are too short. Anyone know a suitable plug for these heads? Thanks
Old 08-24-2024, 09:08 AM   #2
tubman
tubman's Avatar
Default Re: spark plug recommendation
Delete
Old 08-24-2024, 10:54 AM   #3
19Fordy
19Fordy's Avatar
Brian: Peruse the info. on this Google search for: WHAT SPARK PLUGS FOR EDELBROCK HEADS?
https://www.bing.com/search?q=spark+...ANAB01&PC=HCTS
Old 08-24-2024, 11:00 AM   #4
drolston
drolston's Avatar
NGK B-6L have a little over 7/16" reach and should work fine. Or if you want a little hotter plug, the NGK B-4L.
Old 08-24-2024, 12:51 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
There are a LOT more 7/16 reach plugs than 1/2" reach plugs.
If it was mine, I'd be making custom spacers (out of copper) to position 3/4" reach plugs exactly where you want them. There are tons of 3/4" reach plug options - which is why all the newer Eddy heads (and other brands) have switched over to 3/4" plugs.
Old 08-25-2024, 04:34 AM   #6
Brian
Brian's Avatar
Using this chart, I've figured i need NGK B6HS, which cross references to Champion L86C. These plugs have 1/2" reach.
https://www.ngk.com/ngk-spark-plug-numbering-systems
