Old 08-06-2024, 02:47 PM   #1
busmania
busmania's Avatar
Default Running 3 stromberg 97’s questions
I currently run 2 strombergs on an Edmund’s intake. Well, I have all the stuff to go up to 3 carbs with an offenhauser intake. I didn’t do it before because I wanted to keep it simpler while building and starting my first flathead.
Question, can I run the triple carbs with my center water outlet edelbrock heads? Or do I need heads with a front water outlet? This may foil my plan if so (I don’t want to buy and/or replace my heads).
Any photos of triple 97’s installed?
Thanks!
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
