Old 08-16-2024, 11:47 AM   #1
Alberta50fordor
Alberta50fordor's Avatar
Default 1950 glove box latch/lock removal
Does anyone know how to remove the glove box lock/latch? Do you need to remove the dash panel?
I can’t seem to find anything about it in the manual
Alberta50fordor is offline   Reply With Quote
Old 08-16-2024, 08:26 PM   #2
Don T
Don T's Avatar
Default Re: 1950 glove box latch/lock removal
Do you have the key, it should be the same as the ignition unless something has been changed.
Don T is offline   Reply With Quote
Old 08-17-2024, 07:51 AM   #3
32phil
There should be two small screws behind the lock holding it in.
You may have to remove the liner first
FYI
Glove box lock should be the same as the trunk.
Ignition should match door lock.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-17-2024, 02:23 PM   #4
Don T
Don T's Avatar
My apologies to Alberta50fordor; 32phil is correct about the keys. Old brain sometimes malfunctions.
