I have a model A doodle bug tractor. It has 1928 A engine. A 4 speed transmission with a pto on passenger side and an extra shift coming out the rear right and below drive shaft. 1. What is the extra shift? 2. The clutch adjustment is all the way tight. And when disconnected the clutch rod arm sets at the 3 o'clock position. No movement. Is clutch plate fingers out of adjustment?
