Old 06-06-2024, 01:44 PM   #1
Mike1291
Mike1291's Avatar
Default Washer for Rear Backing Plate
I found some unusual hardware when I took off my rear backing plates on my '31 coupe. When someone did the brakes last, they put some sort of washer on the bolts that go through the backing plate. One of my senior club members said that he'd never seen anything like this before. Anyone have an idea why someone might've done this?
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 06-06-2024, 03:01 PM   #2
Big hammer
Default Re: Washer for Rear Backing Plate
To get the cotter pins to align with the nut slots
get a bigger hammer tap done
Old 06-06-2024, 03:02 PM   #3
Benson
A common problem ...
There were two versions of grease baffles:
Early ones use a longer bolt.
Later ones use SHORT bolts and special nuts.
You must have later version baffles with early longer bolts.
You can order the short bolt set from Bert's part A-2248.
https://modelastore.com/
Early bolt sets are not made as far as I know.
Old 06-06-2024, 03:48 PM   #4
Benson
Big Box bolts are not hardened and do not have shanks in the correct places.
https://modelastore.com/index.php?ro...&category_id=0
Old 06-06-2024, 07:03 PM   #5
JayJay
While you are at it, suggest you get a new set of the special nuts to be sure all of your hardware is correct. BTW, last set of the new bolts I ordered were just a hair too large to go through the holes in the radius rods, had to burnish them with sandpaper to get them to fit.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-06-2024, 07:54 PM   #6
Mike1291
Mike1291's Avatar
Funny thing is that the bolts look nearly brand new for being the old style. I see that these nuts are also the later style shouldered nut (per https://www.fordbarn.com/forum/showthread.php?t=262825).
I'll get the later style bolts from a friend who has shelves full of old Model A parts from cars. He even fashioned me with a few original bolts for my fender which was a treat.
Old 06-08-2024, 10:16 PM   #7
Mike1291
Mike1291's Avatar
Took some pictures of my early bolts compared with the later style ones
Old 06-09-2024, 12:32 AM   #8
Tom Endy
Tom Endy's Avatar
The attached article addresses another problem with rear backing plates.
http://www.santaanitaas.org/wp-conte...ing-Plates.pdf
Tom Endy
Old 06-09-2024, 08:50 AM   #9
Mike1291
Mike1291's Avatar
Tom Endy
So my old setup solves both issues you outlined in your article, Tom. The original style bolts have a shorter shoulder area (more threads) so the castle nuts won't bottom out on the bolt. And the washers help to secure the castle nut when you use the cotter pin.
Old 06-09-2024, 05:34 PM   #10
Jim Mason
Jim Mason's Avatar
Look for Steve Plucker's article on backing plates.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 06-09-2024, 05:44 PM   #11
Jim Mason
Jim Mason's Avatar
Check out the rest of the site too
http://www.plucks329s.org/pdf/studie...%20BAFFLES.pdf
Fwiw, jm.
