Old 08-17-2024, 04:17 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default On the car wheel balancing
Does anyone still do on-the-car wheel balancing near Joliet Illinois?
Tim Carlig
dean333 is offline   Reply With Quote
Old 08-17-2024, 04:51 PM   #2
40cpe
40cpe's Avatar
Default Re: On the car wheel balancing
Truck repair shops used to have that equipment if you have one near.
40cpe is online now   Reply With Quote
Old 08-17-2024, 07:01 PM   #3
Clem Clement
Clem Clement's Avatar
What tools do you need? In the past I have had some luck just by taking the pressure off the front bearing and let the front wheels rotate to their balance point. Add a small weight and rotate the wheel again. A couple of tries and the wheel will not rotate on its own.
Then bring the rear wheel up front and do them.
Clem
Old 08-17-2024, 07:12 PM   #4
dean333
dean333's Avatar
Clem, add a weight to the bottom when the wheel stops spinning?
Tim Carlig
Old 08-17-2024, 08:55 PM   #5
Lanny
Lanny's Avatar
With my Snap-On balancer, when letting the tire and wheel make a
slow roll, the heaviest will always be at the bottom when it stops.
Experiment with the weight you add (at the top) to offset the heavy
at the bottom. Then rotate the tire and wheel and it should Stay
wherever you stop it, if you have the right amount of weight on it.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-17-2024, 09:54 PM   #6
Flathead Fever
Flathead Fever's Avatar
I had a friend that the family owned a Cadillac repair shop in the 60s to 80s, I used to hang out there a lot. They had one of balancers that did wheels on the car, but they were the only in town using one. I didn't see any advantage to it other than you didn't need to pull the wheel off of the vehicle. Unless maybe that you consider it's balancing everything that's spinning like the drum and rear axle. But axles are a perfectly straight part and brake drums have balancing weights on them when they were made so there is no reason they would be out of balance. When I to work at the phone company garage, we had a Coats tire machine and a Snap-On wheel balancer. I would take the wheels I had balanced and for fun I would stick a 1/4-ounce weight on the rim and spin it again and it would ask for a 1/4-ounce weight directly opposite of it. The balancer knows which sides of the tire needs the weight but you could also set it so it would only ask for weights on the back of the wheel in case you didn't want to see them. How much better could you ask for. I bought a used Coats tire machine and a Snap-on balancer to mount tires at home. Hardly ever use it, but they are nice tools to have. Years ago, had taken a set of wheels that I had sand blasted, primed and painted with quality automotive paint to have the tires put on. They scratched them up so bad that nobody but me will be mounting my tires ever again.
Old 08-18-2024, 04:56 AM   #7
aussie merc
aussie merc's Avatar
go for balance beads can be a pain to fit but IT WORKS and you can swap rotate etc to your hearts content and it doesn't matter .
aussie merc is offline   Reply With Quote
Old 08-18-2024, 09:16 AM   #8
47topless
47topless's Avatar
Ditto!!!! I like the idea of applying the wheel weight evenly across the wheel, not just on the inside'
Wheel weights can fall off, plus they look like crap.
47topless is offline   Reply With Quote
