what was the difference between the mod A frame and model B frame for the v8, will a flathead be to much for a mod A stock frame ?
All '32 passenger car and commercial vehicle frames were the same at any point in time during the '32 model year, whether for a four-cylinder or V8 chassis. "32 frames have nothing in common with Model A frames.
First I want to be sure I understand the question. You are looking for the difference between the 1928-1931 Model A frame and the 1932 Model B frame? You intend to use a flathead V8 engine? Either frame should be ok for normal driving with a normal flathead. If you use the Model A frame you will need to make front motor mounts. You will need to make a rear transmission mount. You will need to make a mount for the suspension wishbone. You will need to make a mount for the clutch and brake pedals (they were attached to the bell housing on a Model A and the frame on a 1932) and a mount for the master cylinder (assuming you are going to use hydraulic brakes). If you use the 1932 Model B frame you only need to make a bracket to mount the master cylinder. I have included a photo showing the way I mounted the master cylinder on my 1932 frame. The 1932 parts will be more expensive but the work will be a whole lot less. If I misunderstood your question please clarify. What is your whole project?
Charlie Stephens Last edited by Charlie Stephens; 04-22-2024 at 01:18 PM. |
#4 | |
![]() Quote:
