Old 12-06-2023, 07:08 PM   #1
gdmn852
gdmn852's Avatar
Default Inside gas tank finish
Hello, getting ready to repaint the 31 gas tank, have done a search on Ford Barn and also in standards manual , but still have a question on the gloss on the interior side of gas tank , originally were the embossed areas buffed to gloss and rest of tank unbuffed ?Seems to look that way on some original photos. Thank you in advance.
File Type: jpg 837766F2-C577-4C85-9E28-E569C8201102.jpg (106.3 KB, 139 views)
gdmn852 is offline   Reply With Quote
Old 12-07-2023, 01:09 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Inside gas tank finish
Generally speaking, only the face of the tank was hand polished on the DeLuxe models. All the other cars were just 'as-sprayed' Lacquer.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-07-2023, 03:13 PM   #3
JayJay
Be sure you take that fuel gauge out and mask the opening before you paint!
To the original question, my unrestored '30 town sedan has the raised ("embossed") oval portion of the face buffed, and it extends a bit onto the face outside of the raised portion, but it was by no means an excellent job that extended all the way to the edges. Looks like they buffed only enough to lay down the pinstripe. Since this was a hand job likely there is variability between individual cars, but the lower portion of the tank is definitely not buffed.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is online now   Reply With Quote
Old 12-07-2023, 07:00 PM   #4
gdmn852
gdmn852's Avatar
Hello again, thanks for the reply’s , I thought that is what I was seeing on original photos, as I am using bc/cc will have to figure out how much to dull down clear coat .
Old 12-15-2023, 04:05 PM   #5
gdmn852
gdmn852's Avatar
Have the inside gas tank project done, this how it turned out, looks a little odd , but does resemble original photos.
File Type: jpg 51F1DE6E-8784-4408-A4A8-BFF02C12C6F6.jpg (33.6 KB, 109 views)
File Type: jpeg 4DD0EBF2-CB63-4C63-A88A-70E044E5C60C.jpeg (69.7 KB, 107 views)
Old 12-18-2023, 08:27 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Many many moons ago, when I took my 1931 Coupe apart for restoration, I found evidence that the gas tank was mounted in the body before the body was painted. The backside of the tank had a large bare metal area, and so to did the upper part of firewall's interior.
I have seen factory pictures where the gas tank was traveling through the paint booth with, but out of the body so the tank was painted on all of its exterior. My Coupe was assembled during February 1931 in Edge Water, New Jersey, and it was originally Thorne Brown with a Straw pin stripe and black wheels.
Another tidbit of info is that the gas shutoff valve had some Thorne Brown paint on it.
Bob Bidonde
Old 12-18-2023, 10:00 AM   #7
gdmn852
gdmn852's Avatar
This car was about the same as you described, top of inside firewall wasn’t painted and just overspray, mostly bare on inside upper of tank . Originally the car was probably a standard roadster, found traces of Lombard blue, and pins for trunk in the quarter panel for hinge. Thank you for your reply.
Old 12-18-2023, 10:11 AM   #8
henry's 31
It looks great!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 12-19-2023, 06:12 PM   #9
gdmn852
gdmn852's Avatar
Thanks , with two step paint, base coat and clear coat, a lot of masking and time to do the tank, most people just go with gloss.
Old 12-20-2023, 10:27 AM   #10
Smokedtires
Smokedtires's Avatar
Fantastic outcome, well done.
Smokedtires is offline   Reply With Quote
Old 02-22-2024, 05:56 PM   #11
gdmn852
gdmn852's Avatar
Finally got pinstripe done.
File Type: jpg BA2D4487-D7DE-456A-B7D6-7C3B3872CF43.jpg (77.7 KB, 64 views)
