Does anyone know what these tools are and are for flatheads?
Thanks …. |
There's a club devoted to Ford tools: National Ford Tool Collectors https://fordtoolcollector.org/
It's a very small group but someone there might be able to help identify your tools.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
The top one is a universal piston ring groove cleaning tool.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
I'm pretty sure the new wrench is a basin wrench for plumbing.
Edit: Husky adjustable plumbing wrench
Making the simple complicated for over 30 years. Last edited by 51504bat; 02-21-2024 at 06:47 PM. Reason: add photo |
The item in the center with the big wingut is a hand vise. used by machinists, watchmakers, jewelers, etc.
Edit, you beat me to it! |
The third item looks like a jewelers or gunsmith clamp. It looks like this:
https://www.etsy.com/ca/listing/1681...search_click=1 The above is not mine but I have one if anyone needs one for there collection. |
I have a hand vise and use it often.
Wayno
Life is not a spectator sport. |
Hi Tom; The fourth one down reminds me of a wrench for a distributor anchor bolt, or oil pressure sender anchor bolt except the opening seems too large, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
The new shiny one is an adjustable drain wrench. The clamp next to it is actually a small bench vise. The long L shaped wrench below that is an early basin wrench. The home made tools at the bottom are for setting sewer pipe lead joints.
Alan |
#13 |
The only one I can identify is the steel "Vampire Death Spike" - third from the bottom.
#14 |
No, It would have to be made out of wood to work.
#15 |
#16 |
#17 |
My first thought was a wrench to change the oil pressure sending unit, I made one very similar to change the unit on my 40 but agree it is too big.
