I’m curious, do the “High Compression Cylinder Head’s) as sold by Snyders etc. have a different combustion chamber than stock or are they just shaved stock type heads? Put a different way; can you make a high compression head by shaving a stock head? FWIW, I already have one of Jim Brierly’s heads, I don’t actually plan to do this, I’m just curious.
The marketed "high compression " heads have a different shape combustion chamber. Due to the shape of the original Model A head, shaving the head will have little effect on the combustion ratio.
This slide shows the differences between the various combustion chambers.
Bob Bidonde |
The combustion chambers shape of the high compression heads is a much more efficient design than the original design.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#5 | |
![]() Quote:
The ideal chamber design seems to be ignored by the head designers so far. |
To put it bluntly, don't be tight. Buy a HC head that was designed to work at the higher compression ratio.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
I remind you Synchro that I only asked out of curiosity, I already paid up for a Brierley.
A shaved head will work just fine as long as you recut the piston clearance and check to make sure the valves will not hit. You have to take a lot off so you may get into the water jacket. I had a shaved head on my Model T which worked quite nicely. It was a "low head" to begin with so the compression ratio was fairly high. Quite a lot was taken off, over half an inch, so it was into the water jacket in places, but the head gasket sealed off those areas. I had to use shorter head bolts.
Missed that, sorry!
Pete had a valid comment when he said that the ideal design was being ignored. I agree with him. The racing flat heads for the Harley Davidson and Briggs and Stratton engines are more ideal. There may have been some custom heads with more ideal combustion chamber shape, but, in my opinion, none of the ones offered today are.
The incoming air makes too many sharp turns in a flat head engine, especially a Model A engine. It starts at the entry into the block where the air has to make a couple 90 degree turns before getting to the valve. Then it makes another sharp turn to go down into the cylinder as the piston retracts. The inlet port in the block should be angled upwards towards the valve with one port for each valve. Then the part of the combustion chamber that directs the air down into the cylinder should have a generous radius and plenty of area atop the cylinder to allow an easy path for the flow. The intake manifold is another restriction, but that is another subject.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 01-30-2024 at 07:28 AM. |
That’s interesting
The Yapp Lion and Rocket heads are very close to some Briggs Jr drag heads Brierley has a close Harley Davidson design Both of these work very well There are others that require changing pistons but are marginally better If you want more go OHV J
As Carroll Smith wrote; All Failures are Human in Origin. |
The "crowfoot" Winfield head is a good one, Jim Brierly's head looks good also. Both of these are different from each other. Harley put a lot of effort into their design making it worthy of consideration, they also got some good results with it on the track.
OHV is best, but if you can make a Flathead run strong you have something to be proud of. I like my Flatheads. ![]() |
#13 |
In my opinion, Jim Brierley is one of the truly great’s in the world of high performance banger motors. I feel fortunate to be able to acquire one of his cylinder heads, Synchro, it’s cool, I was just messing with you a bit. I always appreciate your input.
#14 | |
![]() Quote:
It is all good old iron making ponies J
#15 |
THANKS jeepguy!
#16 |
Keep in mind a Briggs & Stratton or Harley KR have distant similarity to a model A.
You can only expect their head designs to perform mediocre on a model A, which they do. |
#17 |
Vince Falter covers the various high compression heads frequently found.
He only deals in cast iron heads. Still, a fairly complete examination (including contrasting the various combustion chamber shapes) beginning at https://www.fordgarage.com/pages/ABc...comparison.htm I believe Ricardo did a lot of pioneer work on combustion chamber optimization. https://en.wikipedia.org/wiki/Harry_Ricardo Joe K
Shudda kept the horse. |
#18 |
He who has the head on the engine with the biggest dyno sheet numbers, wins...
Probably still Ed Winfield. |
#19 |
What is y’all’s opinion on the best head gasket for an aluminum head?
#20 | |
![]() Quote:
The exit speed of mile 3 wins Ha! J
