Old 12-02-2023, 05:47 PM   #1
cars2cool
Default Brass fuel gauge float ?'s
I have been trying to order some brass floats from Reenlee Kotas for a couple of months. He is not returning my messages. I hope everything is alright with him. Anybody have contact with him recently?
cars2cool is offline   Reply With Quote
Old 12-04-2023, 02:21 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Brass fuel gauge float ?'s
Not an answer about the gentlemen
But I’ve used old carb floats before …can be mounted and inserted
Old 12-04-2023, 02:48 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have been using the modern car floats leftover from fuel pump module changes
Old 12-04-2023, 04:40 PM   #4
JayJay
I have gotten them from Mikes-A-fordable, and it looks like they may have them in stock.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 12-04-2023, 06:21 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I originally had a cork float, when it sunk it got replaced with a brass one, it cracked and sunk after 18 years, last 20 years has been a modern car black one that was used already and came out of the trash.
Old 12-04-2023, 06:27 PM   #6
Gene F
Gene F's Avatar
What about one of those (copper) round model-B carb floats?
Old 12-04-2023, 08:02 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Whatever float you use has to be able to fit through the hole for the gauge.
Modern cars floats are rarely a problem, and brass last better than cork , the new stuff even still floats if a chunk is broken off,
Old 12-04-2023, 08:49 PM   #8
henry's 31
highly recommend the brass floats from Mikes affordable. Easy to install and your gas gauge problems will end.
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 12-04-2023, 08:52 PM   #9
Tom Endy
Tom Endy's Avatar
A float from a Tillitson carburetor will fit through the tank opening. You can solder it on to the end of the wand. They are pricey from the suppliers. A number of years ago you could pick up a Tillitson at a swap meet for $5. That is what is in my Victoria.
Tom Endy
Old 12-04-2023, 11:22 PM   #10
ursus
Check out the plastic floats sold for use in riding lawnmowers and garden tractors.
Old 12-05-2023, 09:59 AM   #11
Planojc
Planojc's Avatar
Took a gas gauge out of a model a years ago that had a Christmas tree light bulb wired to the shaft, used as a float.
Planojc is offline   Reply With Quote
Old 12-05-2023, 10:20 AM   #12
katy
katy's Avatar
That's a novel idea.
Old 12-06-2023, 08:44 AM   #13
don3527
The A-9313-C composition float is the same black closed cell material used in small engine floats today and is not affected by todays fuels. These are a direct replacement for the original cork float. Don't see any sense in reinventing the wheel to retrofit a brass float. We have sold thousands of these and not had any problems.
don3527 is offline   Reply With Quote
Old 12-06-2023, 11:03 AM   #14
alexiskai
alexiskai's Avatar
100% agree with Don. The brass floats are cute, but they depend on a single large air pocket for buoyancy. If you get one pinhole in the solder – and they regularly do – you gotta pull it out, disassemble, drain completely, dry, find the hole, fix it, reassemble. The risk/reward isn't worth it, and anyway the black foam floats are cheaper.
Old 12-06-2023, 11:17 AM   #15
JayJay
On the other hand, millions of toilets can attest to the robustness of the brass ball. (That's a joke, son. )
JayJay
Old 12-07-2023, 06:44 PM   #16
updraught
updraught's Avatar
Are you pulling my chain?
updraught is offline   Reply With Quote
