Old 11-21-2023, 01:01 PM   #1
Mart
Mart's Avatar
Default 100E part 52! New driveshaft joints. Plus other jobs.
In this episode I fit new joints to the propshaft using firstly a vice and then the press. The press is easier if you have one. I then take care of a couple of smaller jobs, all of which need doing to enable the 100E resurrection to progress.
I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap!
https://youtu.be/_Z-M3B99xJM
Old 11-22-2023, 10:05 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 100E part 52! New driveshaft joints. Plus other jobs.
I had a u-joint fall apart in a dirt parking lot on my ‘60 Falcon Rancharo. Since I couldn’t find all the needle bearings, I cut the heads and points off of some finishing nails, stuffed the joint full of wheel bearing grease and put it back together, I then drove the truck for a while then sold it.
Old 11-22-2023, 10:41 AM   #3
sidevalve8ba
sidevalve8ba's Avatar
I, like you Mart, have done it both ways and indeed the press does a better job of it.
sidevalve8ba is offline   Reply With Quote
