Old 10-25-2023, 09:05 AM   #1
George1348
Default Can't find a replacement single contact socket for 26 tail light.
Hello. I recently bought a 26/27 tail light off a guy and I want to get a new socket for it. However, I cant find any single contact replacements. The ones on Lang's and Snyder's are all double contact. The attached pictures are the socket that was in the tail light when I bought it. I'm looking for one that has the socket on both sides, one for the bulb and one for a plug, as it is my understanding that that was how they originally were. Thanks in advance.
Last edited by George1348; 10-25-2023 at 09:30 AM. Reason: Removing previous edit.
George1348 is offline   Reply With Quote
Old 10-25-2023, 10:55 AM   #2
stevests
stevests's Avatar
Default Re: Can't find a replacement single contact socket for 26 tail light.
No, they were not an original double socket - the photo is of an original Ford part - that small square in the rear is spring loaded and the wiring "bullet" terminal just pushes in.
stevests is offline   Reply With Quote
Old 10-25-2023, 12:09 PM   #3
George1348
Oh, ok. I'm going to have to find a new bullet end for my tail light wire then. Because I had to snip the one that was on there off for the tail light that's currently on the car when I redid all the wiring.
Also, you say it's spring loaded. Mine won't move. how would you recommend getting it unstuck?
Edit: Apparently Lang's has a bullet end for the wire.
Old 10-25-2023, 01:43 PM   #4
rotorwrench
rotorwrench's Avatar
It may be corroded. Try a good penetrating fluid. Hopefully the spring is still functional.
Old 10-25-2023, 04:50 PM   #5
29spcoupe
29spcoupe's Avatar
If all else fails, and the socket is not useable, get the double filament socket and only wire one side of it. Then use either an 1157 bulb for 12 volts or an 1154 bulb for 6 volts.
29spcoupe is offline   Reply With Quote
Old 10-26-2023, 10:54 AM   #6
Will N
Will N's Avatar
I wonder if you could modify or use some of the internal parts from something like a T-Bird backup lamp socket. These are available from several places, here's one https://www.classictbird.com/Socket-...ctinfo/13411A/
Will N is offline   Reply With Quote
Old 10-27-2023, 08:57 AM   #7
redmodelt
redmodelt's Avatar
https://www.autozone.com/power-tools...E&gclsrc=aw.ds
