I have stock rims and tires but want to switch to radials. I also love the look of the bigger hub cap so might as well change both.
I'm thinking about getting '32 18" or the '33-'34 with the 17" but what would be the less expensive tire? Would '35 16" work or would that be too much white wall? I think there are more choices for tires for the 16". I'm going to Gilmore Model A meeting and swap this weeking so hoping I can get some info before I find something and buying them without knowing more. Thanks . . .
if youre going larger, just buy the 16s.
as discussed before, 17 tires are hard to come by. 18s, why bother? might as well stay stock. |
That makes sense. I've seen 16" rims cheaper as well. Plus, it sure does make them easier to spot due to the valve stem location.
You will get many, many opinions at Gilmore. You will also see hundreds of Model A's and should be able to pick a wheel size that looks good to you, tires too.
Several folks in my club have 16" whitewalls on their Model As, and I am going that way for the '30 town Sedan I'm building. Yes, the really wide whites are noticeable, but I don't think excessive. The 16" are considerably less expensive on the swap meet market than the 17", likely because there are more of them around.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
