Old 09-16-2023, 09:25 AM   #1
s.e.charles
s.e.charles's Avatar
Default model A engine dimensions
i've found quite a few specifications, but have not found any physical dimensions or a ('28) model A engine. length x width x height of the block would get me off to a start and any others would be great so i wouldn't be extrapolating or wagging my way through.
i am intending to build a scale Ingersol-Rand compressor circa 1928 in 1:12 scale for my model railroad.
https://youtu.be/BhQ46tf0guM?si=9b2GhDj_3qrepUOq
and direction gratefully accepted!
thanks
s.e.charles is offline   Reply With Quote
Old 09-16-2023, 09:37 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: model A engine dimensions
thanks
On one of the free 3D cad file sites (-like GrabCad, I have seen a complete Model-A engine file set. I am not sure if you could either have your 3D printer scale it, -or whether you could import the file into SolidWorks or Fusion 360 and scale it there, but that may get you the info that you need.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-16-2023, 10:05 AM   #3
s.e.charles
wow. i'm embarrassed to admit i have no 3d printer, or the other 2 programs.
i Do have a box of legos from the local garage sale which i am intending to use for the engine block.
If i get the dimensions. If i can source the correct adhesive. If i get time to do the project.
guess i have more Ifs than technical savvy.
and i pretty much want to keep it that way!
Old 09-16-2023, 12:19 PM   #4
Bob C
Could you use an engine from a Hubley Model A?
https://www.ebay.com/itm/17589949850...Bk9SR4zH2e_TYg
Old 09-16-2023, 04:52 PM   #5
johnneilson
This might get you the information requested
https://www.fordgarage.com/pages/for...rialengine.htm
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 09-16-2023, 05:30 PM   #6
s.e.charles
MOST EXCELLENT!!!!
Thanks so much. i doubt i'll be able to maintain those close tolerances, but it excactly what i was looking for.
very appreciated,
sid
