Old 08-29-2023, 09:37 PM   #1
philcobill
philcobill's Avatar
Default Bouncing coupe
Our 29 coupe is bouncing and I am not sure why. The bouncing is worse at 20 to 35 MPH, and seems to bounce much less at 40 to 55 MPH. Some roads seem to be worse than others. I think we pretty much eliminated the engine (a newly installed Burtz engine) because it still bounces to the same degree whether the engine is revving a bit or when the clutch is engaged and the engine is idling. I suspect something like the shocks and or springs. I would not be surprised at anything. The car is okay to ride in, but the bouncing is a bit unnerving at times.
The shocks were looked at when we had the brakes serviced two weeks ago. I am not sure what the mechanic did. He is on vacation until next week, What reasonable questions should I ask him?
What should be our next step?
philcobill is offline   Reply With Quote
Old 08-29-2023, 10:11 PM   #2
daveymc29
daveymc29's Avatar
Default Re: Bouncing coupe
What type of shocks?
daveymc29 is offline   Reply With Quote
Old 08-29-2023, 10:17 PM   #3
Brentwood Bob
Did this start after the recent service?
Brentwood Bob is offline   Reply With Quote
Old 08-29-2023, 10:22 PM   #4
philcobill
philcobill's Avatar
I am really not sure. The car has been sitting for over two year waiting for the Burtz engine. I had the brakes done when the engine was installed. Before that, I only drove it around for a couple of months, after it had been in storage for over 25 years and rarely started. I am just now fixing things as I come to them. And this bouncing is one of those things
Old 08-29-2023, 10:25 PM   #5
philcobill
philcobill's Avatar
It has the stock shocks. The mechanic looked at them, and may have done something to at least one of them, but I am not sure what. I am just wondering if the symptoms I am describing could be shock related, and if so, should I just have a full service or replacement given the fact the car sat idle for so long.
Old 08-29-2023, 10:48 PM   #6
Marshall V. Daut
If you think it might be shock related, just disconnect the links or arms and take the car for a short drive. If it continues to bounce, the shocks were not the problem. Keep looking.
Check the wheels for roundness. One or more may be out of round or bent. If the wheels have numerous bent spokes, chances are good that the rim is not true, which will cause the car to bounce and/or vibrate at certain speeds.
Also, Firestones and Goodyear tires from 20-25 years ago were egg-shaped when brand-new. Unless the tires were trued on the wheels by a special cutting machine and then balanced, the car will bounce. In the late 1990's, I put all new 19" Goodyears on my '31 DeLuxe Roadster and until I finally took the car to a hot rod shop to true the tires, the car bounced like a clown car in the circus. If you are running older Firestones or Goodyears from that era on your car, that might explain the bouncing.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 08-30-2023, 02:19 AM   #7
jb-ob
Philcobil,
Addition to Marshall's experience, tires will develop flat spots from sitting for extended periods. If you can afford that new engine, include a new set of 'sneakers'. $.02, jb
jb-ob is offline   Reply With Quote
Old 08-30-2023, 03:12 AM   #8
Marshall V. Daut
Ha, ha, ha! 'Good one, Jim!
M.
Old 08-30-2023, 06:02 AM   #9
Ray64
Ray64's Avatar
Maybe one shock partially frozen up
Ray64 is offline   Reply With Quote
Old 08-30-2023, 06:45 AM   #10
philcobill
philcobill's Avatar
Originally Posted by jb-ob View Post
Philcobil,
It may come to that. The car has been sitting for so long, that just about anything could have gotten bad. The tires still have their tread, and are not dry rotting. Just another thing to check out.
Old 08-30-2023, 07:12 AM   #11
Ramman
What if the shocks are empty, misadjusted or not functioning as designed?
Ramman is offline   Reply With Quote
Old 08-30-2023, 08:25 AM   #12
TerryO
TerryO's Avatar
I would recommend radial sneakers...
TOB
TerryO is offline   Reply With Quote
Old 08-30-2023, 06:09 PM   #13
Phil Brown
Phil Brown's Avatar
If all 4 shocks are there and hooked up then it sounds like the shocks might be empty resulting in no resistance to movement. Just along for the ride (a bouncy one )
Phil Brown is offline   Reply With Quote
Old 08-31-2023, 04:18 AM   #14
updraught
updraught's Avatar
We have just got back from a four day crossing of the Simpson Desert (over a thousand sand dunes or something).
The brand new rear shocks blew out on the 4wd after just the first hour. They dumped their oil on the ground. We gained some valuable experience in bouncing. The springs only bounce when you hit a hole or lump.
On the flat it should be smooth sailing.
updraught is offline   Reply With Quote
Old 08-31-2023, 09:03 AM   #15
gdmn852
gdmn852's Avatar
Hello, I would suspect the tires being as old as they are, next bent , out of round rims .After had a blow out with old 12 year old tires,with hardly any miles on them I view old tires with suspicion.
gdmn852 is offline   Reply With Quote
Old 09-01-2023, 03:43 PM   #16
ronn
if your tires are radial, you can have a broken band inside. I had that happen on an old taurus and the rear wheel would go airborn at certain speeds. Made it home going 40mph and found the radial totally cracked. Changed the wheel and good to go.
Old 09-01-2023, 07:59 PM   #17
gdmn852
gdmn852's Avatar
That has happened to me also on newer cars, but I doubt this Model A has radials .It may have rayon or early nylon cords , they were notorious for flat spots, recalling my grandfather had tires that would bang around, shaking the car until they warmed up, almost like an amusement ride.
