Old 02-04-2012, 05:53 PM   #1
26 lakes
Default How to properly warm up a Flathead
I figured the title would get you to look. I am in the process of braking down some stubborn flathead blocks. These were locked up and frozen real good. I fill the cylinders with a little brake fluid and use used paint thinner. I take a plumbers torch and light it. Use some common sense when doing this. No wind or flammables close by. Keep a five gallon bucket of water nearby. I will do this for an eight to ten hour period. I let it cool down between refilling the cylinders. The corrosion on the cylinder walls flakes off. I will shoot it all real heavy with the acetone and transmission fluid solution and let it sit for a week. I squirt down the valve assemblies at any angle I can get to them. I will do the other four cylinders the same way. With the heat you get expansion and the oil goes down around the pistons and the rings. If the block is froze up you have nothing to lose. Try it on your next block. It beats a B_H.
26 lakes is offline   Reply With Quote
Old 02-04-2012, 06:15 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: How to properly warm up a Flathead
Brings new meaning to firing an engine up.....
Bassman/NZ is offline   Reply With Quote
Old 02-04-2012, 06:33 PM   #3
39portlander
39portlander's Avatar
Feeling hot, hot, hot! You gave me an idea for a Flathead grill
39portlander is offline   Reply With Quote
Old 02-04-2012, 06:48 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The only thing missing are the hot dogs and machmillows. Walt
Old 02-04-2012, 07:00 PM   #5
19Fordy
19Fordy's Avatar
Very cool. Opps, I mean very hot. You got "Hot Heads" not flatheads.
Old 02-04-2012, 07:05 PM   #6
denverslim
denverslim's Avatar
I love it! Real flames...slim
denverslim is offline   Reply With Quote
Old 02-04-2012, 07:16 PM   #7
felix37
felix37's Avatar
I will have to try that technique some time.
felix37 is offline   Reply With Quote
Old 02-05-2012, 10:14 AM   #8
Mike51Merc
Mike51Merc's Avatar
I never saw four flatties on fire before. I do see how this could help get a lubricant to penetrate the tight spots, but it scares me at the same time.
Used paint thinner? I would think that used paint thinner would have diluted paint in it, no? I get it, you probably mean unused, leftover, and scrap paint thinner, but what kind?
A word to the wise: this can be VERY dangerous with the wrong chemical cocktail. There's lots of paint thinners out there--- everything from turpentine to laquer thinner to enamel reducer. Some of these chemicals are pretty explosive and a 5 gallon bucket of water will make matters worse with some, not to mention breathing the fumes and what that could do.
I don't mean to be a Killjoy. I've had my share of close calls and burned arm-hair in my past and learned some valuable lessons.
Mike51Merc is offline   Reply With Quote
Old 02-05-2012, 10:20 AM   #9
TonyM
TonyM's Avatar
Yep, 5 gal of water might not be the right choice. Always have a quality (multi use or specialized petroleum) fire extinguisher on hand.
TonyM is offline   Reply With Quote
Old 02-05-2012, 12:22 PM   #10
Ralph Moore
Ralph Moore's Avatar
I like it!, Of course I always like playing with things that burn, or blow up! I passed on a bunch of froze up flatheads, about 20, last summer. I just might have to go back and get some, or all of them now. My wife is going to love that!
Ralph Moore is offline   Reply With Quote
Old 02-05-2012, 01:11 PM   #11
richard crow
best way to heat a flathead is drive it on sunday on the lie in july
richard crow is offline   Reply With Quote
Old 02-05-2012, 01:34 PM   #12
outlaw256
if it works great. but be very careful what you mix up and set on fire. or you may have to go a few blocks over to get your engine back.or pull it out of someones living room .lol
outlaw256 is offline   Reply With Quote
Old 02-05-2012, 03:08 PM   #13
26 lakes
It is hard to ignite the paint thinner. That is why I use a plumbers torch. You have to hold it on there a couple of seconds to get it to burn. It is not like lighting gasoline. Paint thinner burns slow and produces low heat. I am a painter by trade. I have old paint thinner that I keep around. I recycle it this way. I am using PAINT THINNER or MINERAL SPIRITS. That is it.
Old 02-05-2012, 05:49 PM   #14
out plowing
out plowing's Avatar
More like "How to roast a flathead" or "My wife burns candles for therapy, I burn Flatheads"
out plowing is offline   Reply With Quote
Old 02-16-2012, 05:23 PM   #15
Jason in TX
Jason in TX's Avatar
Cool Dave!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 02-17-2012, 12:27 AM   #16
Fairlane500
Fairlane500's Avatar
Did it work???
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 02-17-2012, 12:38 AM   #17
26 lakes
It works on every block I have done it to. I have done some really cruddy blocks.
Old 04-23-2014, 11:12 PM   #18
Liftedck
I really like this idea. I have a couple blocks worth trying this on.....very neat
Liftedck is offline   Reply With Quote
Old 07-07-2018, 05:08 PM   #19
Mart
Mart's Avatar
Goodness gracious, great bores of fire!
Old 07-07-2018, 05:54 PM   #20
Graeme / New Zealand
Graeme / New Zealand's Avatar
"fire in the hole"!!
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
