Old 07-19-2023, 04:23 PM   #1
Roger W Gerow
Default Starter Drive Gear
Bought a39/40 without a starter the other day. I installed a known good starter but there is a problem. From what I can see, the cover over the end is missing, ;the drive gear appears to striking the flywheel preventing it from engaging the flywheel teeth! Tried another good starter, same problem. The engine has 59AB heads, so the engine has been overhauled in the past. HERE'S MY QUESTION. When starters have been discussed it seems there is a difference between the automatic transmission and standard transmission drive mechanism! What is the difference. Is the diameter of the drive gear smaller on the automatic system? Are the teeth on the flywheel different? Open for suggestions.
Thanks, Roger
DD658
Roger W Gerow is offline   Reply With Quote
Old 07-19-2023, 05:39 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Starter Drive Gear
Thanks, Roger
Standard and automatic are two different animals.
