05-17-2023, 10:21 AM | #1 |
camshaft assembly lube and break in oil
there's a ton of it out there what are you engine builders using in your motors for first start up ? I'VE used STP and reg oil but those motors were just rebuilds of the old motor, never had a problem. This flathead is all new and i don't want any problems,
thanks kurt |
05-17-2023, 10:58 AM | #2 |
Re: camshaft assembly lube and break in oil
In my opinion the critical parts during break in are the cam and lifters. I always use the recommended initial cam lube from the manufacturer on lobes and lifter bottoms. Many manufacturers make a "break in oil" for the first few hundred miles. The stiffer your valve springs the more critical it is. On my Brand X engines, I run them no slower then 1000 rpm with bursts higher for about 20 minutes before I let it idle.
I would think a stock flathead would be fine running with the specified cam lube, high performance, cam and lifter lube plus break in oil. This info is just from my experience, I am not a professional engine builder but have done lots of later engines and 7 flatheads. My 2 cents. (have never had rings that didn't seat) |
05-17-2023, 02:20 PM | #3 |
The rings as mentioned above will break in fine under normal and hard use I find there's no need for any break in period for the engine. Ronnieroadster.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
