Old 05-01-2022, 08:26 PM   #1
HopRod
Default No oil pressure on fresh rebuild
Just tried starting new rebuild and could not develop any oil pressure. I previously forced oil in the rear tap a couple weeks ago to prime the pump, but has been two weeks ago. The motor started, saw the oil pressure gauge flutter a little bit and then settled on 0. I thought it should have picked up the oil from the pan. Using electric fuel pump with push rod hole plugged. Front galley plug is installed.
Any thoughts?
HopRod is offline   Reply With Quote
