Old 02-28-2023, 03:42 PM   #1
jstrez5
Default 39 ford spring measurment
would anyone know the correct measurment on the front and rear springs from eye to eye on a 1939 ford deluxe original springs i am in the process of buying front and rear and they tell me they measure 48 1/2 inches i just want to make it right the first time any help would be appreciated. thank you jim.
jstrez5 is offline   Reply With Quote
Old 02-28-2023, 07:13 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: 39 ford spring measurment
I have the car, original springs in it.
May have the spare springs outback. (off of a 1937)
It's raining here, don't want to go digging now
PM me and I'll see what I can do.
Karl
Karl Wolf is offline   Reply With Quote
Old 03-01-2023, 07:53 AM   #3
Chuck Kuntz
I am in Altoona and probably have what you need. I will check this morning and get back by noon. YOu could save a lot by picking them up vs. shipping.
Chuck
Chuck Kuntz is offline   Reply With Quote
Old 03-01-2023, 06:10 PM   #4
rockfla
rockfla's Avatar
if it helps, just measured my 39 Mercury front spring, hard to do it by myself lying down but i’m gonna say 42-1/4” “ISH” center to center and under load
Old 03-01-2023, 06:16 PM   #5
fordv8j
fordv8j's Avatar
I think it would be better to measure from the center bolt hole to center os shackle bolt hole'''just my thoughts
fordv8j is offline   Reply With Quote
Old 03-01-2023, 08:10 PM   #6
Kube
Kube's Avatar
A spring is not measured accurately when not under load.
A used spring will have a wider center to center than a NOS spring. Even the NOS springs I have vary by as much as 1" or so.
Old 03-01-2023, 09:52 PM   #7
Zeke3
Zeke3's Avatar
I have a NOS 11 leaf front spring 78-5310-C that is not installed. It measures 36.5" center to center.
Zeke3 is offline   Reply With Quote
Old 03-14-2023, 07:36 AM   #8
Kube
Kube's Avatar
I have attached three photos that should make it quite clear why the measurement you seek is meaningless.
These springs are identical except one is used, as removed from the '40, the other is NOS.
Note the differences in height and width.
