Hi gents-
I'm installing a new trunk light extension wire in my '48 Ford convert. Where should this wire enter the trunk? I have replaced the floor pan. Thanks, R Sullivan |
On the 41s , its always entered on the driver side hinge . But that’s probably the obvious, do you want where it feeds from ? IIrc it comes from the lower left and up the driver side rear inner fender well . I’ll check later to be sure .
Both 41s and my 46 have the wires coming from the left frame rail up through a hole Bout 8-10” above the fuel fill hump in the trunk . Then it runs up to the rear package shelf area / left hinge to the trunk light switch .
Hope this helps |
R Sullivan |
