Old 02-22-2023, 12:49 PM   #1
HDowse
HDowse's Avatar
Default Water pump - repair or replace
I've been working on the 1937 pickup for a while. While underneath the truck, I noticed coolant seeping from the shaft of the left water pump. I have several options: buy a rebuild kit with a new seal, send the pump out to one of our expert rebuilders or buy a new pump advertised with new housing, ceramic seal, sealed ball bearings and new helical impeller for improved cooling. I'd like to try the rebuild but haven't done one but have seen Mart in England rebuild one and it doesn't look too bad. Questions: can the lower hose be removed/replaced without removing the radiator? Do I rebuild both on general principle or try to avoid fixing something that isn'r broke? Thanks for your input.
Hunt in soon to be freezing rain, sleet and snow southern NH
HDowse is offline   Reply With Quote
Old 02-22-2023, 01:31 PM   #2
TJ
TJ's Avatar
Default Re: Water pump - repair or replace
First tap on the pulley with a hammer and it may stop leaking. Sometimes a small piece of rust gets in there between the shaft and seal and causes the leak. Tapping with a hammer may dislodge it.
Old 02-22-2023, 03:28 PM   #3
Kube
Kube's Avatar
I'd rebuild them both. I'd send them to Haney.
Most likely they were both installed at the same time. If one is leaking, again, most likely, the other isn't far behind.
Heck, the radiator is drained, now is the optimum time.
Yes, you may R&R the hoses with the radiator installed. It's a pain in the butt job but very doable.
Boiling the hoses for a little time helps tremendously.
Old 02-22-2023, 03:34 PM   #4
Tim Ayers
Agreed. Kind of like headlight bulbs. When one goes, the other is shortly behind.
Thanks for the boiling tip. Never thought of that, but makes perfect sense.
Tim Ayers is online now   Reply With Quote
Old 02-22-2023, 04:00 PM   #5
HDowse
HDowse's Avatar
TJ, Kube, Tim and CAVictoria: thanks for the advice on the pumps and hoses. I'll contact Skip and see how busy he is these days. Probably very. Thanks again.
Old 02-22-2023, 05:11 PM   #6
Newc
Newc's Avatar
there was a fellow an CA , rebuilder of pumps also. Mine came back with snazzy new brass impellers. Newc
Old 02-22-2023, 06:58 PM   #7
Kube
Kube's Avatar
George, busy or not, is quite prompt. he's a good guy you can count on.
Old 02-22-2023, 07:00 PM   #8
Tim Ayers
Agreed again. I'm not sure how he does it, but his turn around is quite prompt.
Old 02-22-2023, 07:15 PM   #9
Angledrive
Angledrive's Avatar
He has done so many of them he can do them while he is sleeping.
Angledrive is offline   Reply With Quote
Old 02-23-2023, 02:54 AM   #10
deuce lover
deuce lover's Avatar
The fellow in CA is Daryl Fryer and also advertised in the V8 Times. When I lived in CA I sent my pumps to him and was very pleased. If Skip is backed up give Daryl a call .He is in Redlands -near Riverside.909-335-1418.
Old 02-23-2023, 05:51 PM   #11
alchemy
alchemy's Avatar
You know about the hidden bolts, don't you?
alchemy is offline   Reply With Quote
Old 02-24-2023, 03:45 PM   #12
blackforty
or buy new ones? good luck either way.
blackforty is offline   Reply With Quote
