Old 01-28-2023, 04:23 PM   #1
d.conrad
d.conrad's Avatar
Default Firestone bias ply run tubeless???
Have any of you used Firestone bias ply tires without a tube on '40 Ford 16'' wheels?
d.conrad is offline   Reply With Quote
Old 01-28-2023, 06:44 PM   #2
cas3
Default Re: Firestone bias ply run tubeless???
There's quite a few threads here on the subject. General thoughts are if your wheels are in good shape, go for it.
Old 01-28-2023, 07:38 PM   #3
Kube
Kube's Avatar
Okay, gotta ask... "why would you want to"?
Old 01-29-2023, 11:13 AM   #4
Mart
Mart's Avatar
NO DON'T DO IT!
Firestone bias ply tires are not tubeless!
People do run tubeless tires tubeless but you can't run a tube type tire tubeless.
Please be careful when giving advice when it is safety critical.
mart.
Old 01-29-2023, 01:37 PM   #5
rotorwrench
rotorwrench's Avatar
If it was a tractor then I'd say go for it but anything that goes faster than 35 mph and has riveted center wheels, I'd say put tubes in there. Modern radials can work to a point but the old rims don't have the safety bead like the more modern ones after the late 1950s.
Old 01-29-2023, 05:00 PM   #6
d.conrad
d.conrad's Avatar
With 9000+ miles on a set of 6.00-16 Firestone bias ply tires I had a blow out. The tube had a series of small holes in the wheel side of the tube. My guess is the installer may have scuffed it when he installed it. If hadn't had tubes I wouldn't have had a BLOWOUT. I'll try to put a picture of it soon. Some of the guy above have good luck with them. I'm getting ready to get another set of 6.00-16s to replace the radials on my '40.
Old 01-29-2023, 05:51 PM   #7
Mart
Mart's Avatar
I don't get this.
Tube type tires need tubes.
Tubeless tires do not need tubes.
Where is there any room for discussion?
Old 01-29-2023, 08:04 PM   #8
JayChicago
JayChicago's Avatar
Would a tube type tire even hold air without a tube in it? For how long? I thought only tubeless tires were manufactured with a bead surface to provide an air-tight seal against the wheel.
Old 01-30-2023, 07:58 AM   #9
Mart
Mart's Avatar
^^ Exactly!
Old 01-30-2023, 09:11 AM   #10
truckdog62563
truckdog62563's Avatar
I had a conversation with an STA tech rep about this a few years ago to get a scientific answer for a guy. Guys over on FTE were claiming they ran tube type tires without tubes with no issues. Tech rep said tube type tires lack the inner liner molded into tubeless tires. Might hold air for a while but over time will seep and deflate. The lesson is to follow manufacturers’ guidelines. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 01-30-2023, 10:06 AM   #11
rotorwrench
This doesn't have much to due with cars but I'm adding it anyway. I live in mesquite country here in south Texas. My old Ford 850 tractor is designed for tube type tires. The rear ones aren't that big a problem but the fronts will go flat right away when cutting mesquite brush due to the nice long thorns on them. The tubes just wouldn't work with tire sealer so I took them out so that the sealer could be effective. It works for about two seasons before new sealant has to be added. A person can see thorns sticking out all over them and I leave them in there to slow the leak rate. They hold air pretty well considering but during the off season, I have to drive the tractor at least once every two weeks to residtribute the sealer in the tires or they will start to go flat.
All this sure is better than replacing or patching a tube every time a tire goes flat.
Old 01-30-2023, 10:09 AM   #12
Seth Swoboda
Seth Swoboda's Avatar
I was unaware that you could run a bia-ply tire without tubes?
Old 01-30-2023, 11:22 AM   #13
Zeke3
Zeke3's Avatar
There were bias ply tires that were tubeless, they were used on all domestic passenger cars from at least the mid 1950's through the 1960's. I can't speak for the tires currently produced.
Zeke3 is offline   Reply With Quote
Old 01-30-2023, 11:49 AM   #14
JayChicago
JayChicago's Avatar
That could be the answer. The reproduction bias ply tires sold today may be manufactured to tubeless tire standards.
Old 01-30-2023, 12:40 PM   #15
V8 Bob
V8 Bob's Avatar
You will find bias (and radial) tires made today that are tube and tubeless, depending on manufacturer and/or size. Some run tube tires without tubes, but I wouldn't. Best to stay with the original design spec.
Old 01-30-2023, 02:46 PM   #16
B-O-B
B-O-B's Avatar
A bit curious here & just asking. I'm sure someone has thought of making a solid rubber tire just for such purposes. Is it cost prohibitive?
B-O-B is offline   Reply With Quote
Old 01-30-2023, 02:53 PM   #17
ford38v8
ford38v8's Avatar
Bob, I assume that your question is referring to the post from rotorwrench above? I'm no farmer, but I was thinking the same thing.
Alan
ford38v8 is online now   Reply With Quote
Old 01-30-2023, 04:51 PM   #18
cas3
I've run skid steers with foam filled tires. They ride like fred flintstones car, and you loos some traction since the tires do not "give" at all.
Old 01-31-2023, 09:09 PM   #19
B-O-B
B-O-B's Avatar
Yep. Sorry about that, I guess my old age is beginning to show!
Old 01-31-2023, 09:54 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
If all we did was stay with ORIGINAL design specs, this is how we would be flying to see Grandma!
Coop
Click Links Below __
T5 W/TORQUE TUBE
