Old 01-21-2023, 02:32 PM   #1
mleder
Default Highway speed 4.75 " x 19" tires vs 6.00 x 16"
Could all math wizards tell me what for instance if my car has the 19" tires and with a 3.78 rear end and a set engine rpm that gets me 55 mph on that tire size with the same conditions what would the highway speed be with a 600 x 16" tires fitted to the car. For extra credit what tire size, make brand may get me closer to the highway speed of the 19" standard tire.
mleder is offline   Reply With Quote
Old 01-21-2023, 02:37 PM   #2
Dan in MI
Dan in MI's Avatar
Default Re: Highway speed 4.75 " x 19" tires vs 6.00 x 16"
Teacher always told me to do your own work.
https://purperformance.com/p-29669-rpm-calculator.html
Dan in MI is offline   Reply With Quote
Old 01-21-2023, 04:48 PM   #3
lrf
My automotive teacher was my Dad who always said "stay away from old cars, they're nothing but trouble." I now own seven.
lrf is offline   Reply With Quote
Old 01-21-2023, 06:00 PM   #4
Synchro909
Synchro909's Avatar
54.035 mph.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-21-2023, 06:39 PM   #5
Joe K
Joe K's Avatar
You should find the highway speeds "similar."
As it turns out the "exterior diameter" of the wheels are approximately the same. Fatter tires yields "taller" tires too.
I expect you could measure the circumference of each and thereby get REAL close to an actual ratio - but inflation pressure, or more accurately 'resilience' of the tire (i.e. "the squish") may differ slightly making circumference an approximation of actual "wheel ratio."
Joe K
Shudda kept the horse.
Old 01-21-2023, 10:12 PM   #6
GSleater
GSleater's Avatar
I've found its roughly 5mph difference and that was using my GPS.
GSleater is offline   Reply With Quote
Old 01-22-2023, 12:01 AM   #7
jack backer
285/75/16 31”diameter tire.. Amazon cheapies work for me
jack backer is offline   Reply With Quote
Old 01-22-2023, 04:25 AM   #8
ronn
Joe K. well explained.
Old 01-22-2023, 12:15 PM   #9
AL in NY
AL in NY's Avatar
I use 225/75R16 tubeless radials on the 16" 1935 Ford wheels. The diameter is just an 1/8 inch difference then the stock 4.75/19 tires, so the speedometer is within one MPH of stock wheels and tires. Two big advantages here, better braking and handling plus no more tubes!!!!
I bought Westlake tires at Walmart, on sale for $70.00 each.
Tire height: 4.75x19 tire is 29.00 inches
285/75R16 is 32.8 inches
225/75R16 is 29.3 inches
AL in NY
AL in NY is offline   Reply With Quote
