Old 03-13-2022, 12:38 PM   #1
harleycontracter
Default Lowering Front and rear
Can I lower the front and rear a bit by suspension and leave everything else as stock. Alter springs ? ??? Thanks
harleycontracter is offline   Reply With Quote
Old 03-13-2022, 01:08 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: Lowering Front and rear
How far are you looking to go?
Harpkatt is offline   Reply With Quote
Old 03-13-2022, 01:41 PM   #3
harleycontracter
I'd like to go like 3" give or take Txs
Old 03-13-2022, 03:41 PM   #4
Chris Haynes
Chris Haynes's Avatar
This is a 3 inch drop and still looks stock. 1932-1936 axle with a Posies 2 inch drop spring. Posies can also supply a spring to drop the rear.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-13-2022, 05:19 PM   #5
Synchro909
Synchro909's Avatar
That picture is in Photobucket which makes it useless to most of us. There has been much "discussion" here about what that company does.
All I get when I click on the picture is advertising wanting me to open an account. NO WAY!
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-13-2022, 09:49 PM   #6
bruceincam
bruceincam's Avatar
Same here ---------
bruceincam is offline   Reply With Quote
Old 03-14-2022, 02:46 AM   #7
bavArian
bavArian's Avatar
Just rightclick and open the picture (not the link) in a new tab/window.
bavArian is offline   Reply With Quote
Old 03-14-2022, 06:06 AM   #8
brokenspoke
Go to the HAMB and search the Monthly Banger Meet you will find lots of info
brokenspoke is offline   Reply With Quote
Old 03-14-2022, 06:13 AM   #9
nkaminar
nkaminar's Avatar
Back in the day we would "torch the springs" to lower a car. The springs were heated with a acetylene torch until they bent. To raise a car we would reverse the shackles, which would not work on a Model A.
Old 03-14-2022, 08:43 AM   #10
rotorwrench
rotorwrench's Avatar
Reverse the spring eyes and remove leaves. This will lower the car a bit but removing leaves reduces spring capability. Reversing the eyes is the least invasive way to alter the height. Dropping the front axle and stepping the rear frame rails in front of the cross member is the old traditional way but the car will be altered a good bit doing that.
Old 03-14-2022, 09:52 AM   #11
California Travieso
Send a message via Yahoo to California Travieso
Can’t “right click” on an iPhone or a iPad.
David Serrano
California Travieso is offline   Reply With Quote
Old 03-14-2022, 03:07 PM   #12
Chris Haynes
Don't click on the picture. Simply look at it.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-16-2022, 10:42 AM   #13
VintageSpeed83
Kohler Kustoms, Andy will lower the front and Old Yankee Speed Co makes lowering springs for rear
VintageSpeed83 is offline   Reply With Quote
Old 03-27-2022, 11:25 PM   #14
PotvinV8
PotvinV8's Avatar
Reverse-eye main leaves will get you two-inches in drop, Posies offers a "low reversed-eye" that will get you another inch. Model T rear spring will result in similar drop. If you want more, you can pull leaves out of the pack, just be sure to not pull a bunch of consecutive leaves as each leaf serves to spread the load. In other words, you want the "span" between the ends of each leaf to be as close as possible.
For example, if you pull the second and third leaf, the distance between the end of the fourth leaf and the spring perch of the main leaf is beyond the design of the spring pack and can put additional stress on the main, since each leaf provides support to the pack. Hope that makes sense.
PotvinV8 is offline   Reply With Quote
Old 03-28-2022, 08:46 AM   #15
jack backer
Why not hop it up too?
jack backer is offline   Reply With Quote
Old 03-28-2022, 12:12 PM   #16
PotvinV8
PotvinV8's Avatar
Good idea!
Old 03-28-2022, 01:49 PM   #17
J Franklin
J Franklin's Avatar
Is this the look you want?
Old 03-28-2022, 03:37 PM   #18
California Travieso
Talking Re: Lowering Front and rear
. . . and chop the top while you’re at it!
David Serrano
Old 03-28-2022, 05:38 PM   #19
jack backer
There’s a whole lot of folks who hop up ford flathead four engines from 28-34.. not too many put the saw their cars. But if they do, it’s their car,I defended their right to do as they wish with their private property and continue to back that freedom. If you want to stop someone from cutting up their private property I suggest buying it from them.
Old 03-28-2022, 06:26 PM   #20
Step-down
Step-down's Avatar
No frame mods
Model T Rev eye in rear 9 leaf ,750 x 16
Front 4” drop rev eye 9 leaf , 600 x 16
File Type: jpg FF85D0D1-3761-465C-8A28-90D24E17DDB9.jpg (72.4 KB, 118 views)
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
