I have a 34 p/u V-8 (3-3/8” x 4”) with a 4” dropped straight axle and wishbone. I have upgraded to disc brakes and plan to use a Vega cross steer setup. My question is what headers work in a 34 due to narrow frame rails? Any and all suggestions would be greatly appreciated.
Thanks, Stephen |
Since you're running a Vega box up front, you should be able to use regular 1934 Ford headers (Red's Headers). If it was mine, I'd prototype the setup with the headers and steering box - to make sure your steering shaft setup doesn't have any issues.
The repro cast iron Fentons fit my 34 coupe with a 59a and stock steering box, just barely, 1/8 " clearance to the box. I know nothing about vega boxes
#4 | |
One option is to keep the stock manifolds and, if you prefer something better looking, send them out to be coated with one of those chrome-like high temperature ceramic coatings. |
