So I have a new bearing for a 39 trans input shaft. Really really tight fit. I have the shaft in the freezer now and am planning on heating bearing in the oven. Any other tips will be appreciated.
The bearing should be a press fit onto the shaft. I do them without freezing the shaft or heating the bearing. I wouldn't suggest heating the bearing as the pre-lube will melt from the bearing.
Hopefully others will chime in here. Paul J |
Heating the bearing will be fine...I keep it to 450F or less. It should just drop on if you work quickly with a cold input shaft. I do like to have a length of pipe that slips over the shaft and bears on the inner race just in case it needs a bit of help going on. Lube isn't a problem since the bearing runs in oil anyway. Just oil it before assembling the trans.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
I have never had a problem with just pressing it on. In the modern world, I like a sealed bearing, then remove the inside seal so it gets transmission oil like it should. I also like to search the bearing numbers to find old stock USA made bearings
Usually light press fit. There may be flat spots on the input shaft.
Mac VanPelt's transmission book is a must have. He is a good source for parts as well. The bearing that fits in the input shaft is better if an original part or NOS. Some of the new ones are crap. I would reuse one that is still in good condition and not think twice about it. |
