Old 09-12-2022, 08:23 PM   #1
chkolar
Default water pump grease
What is the best grease to use on an original water pump?
chkolar is offline   Reply With Quote
Old 09-12-2022, 08:44 PM   #2
mhsprecher
mhsprecher's Avatar
Default Re: water pump grease
For the fitting next to the engine, use this: https://www.brattons.com/WATER-PUMP-...uctinfo/12270/
The front bearing can use regular chassis grease.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 09-13-2022, 10:10 AM   #3
rotorwrench
rotorwrench's Avatar
Water pump grease has to work when wet and have a low enough melting temperature not to clog up the radiator tubes. I use Lubriplate 130-AA.
