Is there any other rear brakes that can be used on a 40-48 car ?
The bendix brakes, as used on lincolns and repopped...however, do the front brakes too, otherwise the brake bias is totally wrong and dangerous; the bendix brakes are far superior to the Ford Lockheeds!
I have stock '50 Olds self-energizing brakes on the '28 Ford Mitchell Muffler Pickup that were installed when the flathead drivetrain was switched out for Olds power back in 1950. They kept the Early Ford hydraulics on the front. That sucker stops really well and straight. There is nothing unsafe about the balance of the brakes. It's the rest of the car that feels like a death trap to me. Here some photos of the entire drivetrain swap in 1950.
The Mitchell Pickup was the first hot rod ever road tested in a magazine. Wally Parks did the testing in Hot Rod Magazine. He was happy with the self-energizing brakes on the rear and the Early Fords in front, except that they were sensitive and slid with too much pressure because of the light weight of the car. A '40-'48 car is going to stop differently. I'm building a '34 pickup with Lincoln brakes front and rear. On my '32 roadster highboy project I like the radiational look of the Early Ford backing plates on the front so I might run Lincolns just on the rear. I have a '32 2-window that somebody started building. Early Halibrand in the rear with F-100 self-energizing brakes, on converted 9-inch axles and Early Ford Brakes up front with Buick drums.
It's been years since I started the Mitchell Pickup up. I think it was the last Pasadena Reliability Run. It sees daylight about every ten-years. It should have that barn-find patina by now. Last edited by Flathead Fever; 07-01-2023 at 07:21 PM. |
Sadly, Boling Bros. is out of stock re: 40-48 brake drums. If anyone knows of a set for sale there is a Fordbarner looking for rear brake drums.
A few years back I installed an Auburn two speed diff into my jailbar. The Auburns used 12" Bendix brakes, like Lincolns of the era. That jailbar was downright dangerous with the Lockheeds on front and Bendix on rear; the rear brakes would lock up with the resultant crazy antics...I fixed it by adapting 12" bendix brakes to the front.
That is my experience, hence my warning in my above post.
Thanks for all your comments, I am listening for any solutions you's might have. Moe
coolcoupe: Keep in touch with Krylon32. He is a Boling Bros vendor, knows their products and stands behind them. I bought my complete MT Lincoln brake kits from him years ago and am still very happy.
Got a reply from Boling Bros. They have drums, & backing plates. I have a source for US made front hubs but you must reuse the rear hubs with new studs for a rear conversion. There is a company selling Chinese hubs but they have had some problems with some of them.
So you are saying if I buy new front drums I can use them on the rear if I install my rear hubs ? If so why would I need new studs ? Moe
#13 |
The original studs are swedged; the swedge needs to be cut to remove the original drums. The swedge is easily cut with a 5/8" hole saw. The original studs will no longer work and would be too short anyway as the cast drums are thicker than the original drums. Boling Bros lists the part number for the studs on their website and also sell a kit with serrated studs and a reamer, or you just get studs locally if you have the means to open the holes to .60.
#14 |
Thanks Rich. I suppose I should have explained.
#15 |
If I install the rear hubs in the new front drums it'll work ?
#16 |
There are no front drums, the same drums work front and rear. You can use your stock hubs with new studs. I assume your thinking of doing the BB 12 inch rear backing plates? Another option is to use the BB backing plates with the 1.75 wide shoes and use your stock drums. I've sold several kits F&R to customers using the 1.75 shoe BB backing plates and retaining their stock Ford drums. Several different options.
#17 |
Hi Krylon32, I have 2 really good front drums but I need 2 rear drum/hub.
Can I ream out my no good hubs and install them in my other really good set of drums ? Can I buy the correct longer studs from you ? Thanks for now, Moe |
#18 | |
![]() Quote:
Coop . |
#19 | |
![]() Quote:
Replacing the studs in no big deal. You need to ream out the holes approx. .010 (Boiling brothers will tell you and now sell the correct studs) and the new studs are toothed so the will wedge into the old hub. Nice thing about using Boiling Brothers drums is you can take the drums off without a puller since they become slip on drums like a "modern" car. I highly recommend using their drums. They are excellent and perfectly round out of the box. |
#20 | |
![]() Quote:
It took me a few hours going through the Dorman catalog to find the correct ones. Glad Coop posted the correct part number. |
