Old 07-31-2022, 04:48 AM   #1
UPS Driver
UPS Driver's Avatar
Default 1929 Tudor steering box ID
Steering box is a little bit loose and I’m wondering what I have it’s marked Gemmer 2 or 7 tooth
Also when I turned on headlights the ammeter went into a 10 amp discharge ( has a NU-Rex 6volt positive ground alternator) belt probably had an inch inch and a half play VERY loose is it possible this is a culprit for a no charge problem? Thank you to all for the help !
Brian
File Type: jpg F09F71EC-3F6F-4FAF-B00A-EEFFD6BE4FE2.jpg (46.8 KB, 52 views)
File Type: jpg 727FA63E-DA69-4266-AAE5-9CF765AAA80F.jpg (55.3 KB, 48 views)
UPS Driver is offline   Reply With Quote
Old 07-31-2022, 07:26 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1929 Tudor steering box ID
Ford made the 7-tooth. Gemmer designed the 2-tooth but if Ford was to use the design, Gemmer had to give them the rights to it which they did. Ford was building so many cars in 1929, They had to use all available sources so 7-tooth and 2-tooth were both produced in high numbers in that year. After Ford started to produce the Gemmer design in sufficient quantities, the 7-tooth was slowly phased out.
It certainly could be belt tension. The model A water pump needs some slack but not that much. Half an inch is good. If it still won't pull its weight then check all connections for looseness or bad ground pathways. The lighting system can have crusty ground pathways due to the way all of the lamps are mounted and their distance from the power source. The headlamps are the largest continuous current draw in the electrical system.
Old 07-31-2022, 07:30 AM   #3
UPS Driver
UPS Driver's Avatar
So it’s a 2 tooth and rebuilding shouldn’t be a problem. Thank you
I’m going to play around with it this afternoon it’s strange that it goes back to a zero charge with the lights off
Old 07-31-2022, 09:43 AM   #4
katy
katy's Avatar
Was the engine running?
Old 07-31-2022, 12:17 PM   #5
UPS Driver
UPS Driver's Avatar
Yes it was running at idle I revved the engine to try and “excite” the alternator as well . I’m not sure what’s going on the belt is very loose. Grabbing the fan and turning by hand only moves the water pump and it’s adjusted all the way out with the nu-rex bracket
Old 07-31-2022, 12:58 PM   #6
UPS Driver
UPS Driver's Avatar
I just noticed that someone has put “modern “ wiring with cloth over the rubber sheeting we see on wiring today also the negative goes to the starter and wires go from the starter to a “distribution box” on the firewall and at the starter the connector that goes to the box looks weak (like wires loose In the crimp) I’ll have to play with it and chase it down it can’t be too hard. Now to switch to a 12 volt system from the 6 volt besides changing bulbs and the coil what else is needed? I really never cared for 6 volt anything. I have multiple antique tractors and if the 6 volt works (usually not) I leave it alone but if it’s a problem I’ll switch to a one wire GM alternator and eliminate the problem and move on. This car is not and never will be a museum piece so I’m not worried about the original setup anyway. It’s confusing why switch to a 6 volt alternator and not do a 12 volt?
Old 07-31-2022, 04:29 PM   #7
rotorwrench
As long as the wiring is the correct gauge and the terminals are soldered then 6-volt works fine. The terminal box under the coil is the firewall carry through to the amp meter. It's also the power source for the coil and the instrument panel light.
Changing to 12-volts is mostly a matter of dealing with the coil and all the light bulbs. The horn fields can easily be rewound for 12-volts if needed. It's just more work to get it where 6-volts could still do the same job. The 6-volt GM alternator conversion kits can be purchased to overhaul one of the 1-wire units like the GM 10si or a person can just use the 10SI on 12-volts. Add a generator out light for a 3-wire set up and it will excite as soon as it starts turning. The voltage regulation on the 12-volt units is better than the 6-volt conversions too. 12-volt batteries are available in the sizes that fit the OEM battery frame but a person has to get the ones with the posts in the right place for either negative ground or positive ground. Negative ground would make more sense on a 12-volt system. Polarity for the coil would be affected but that's about it.
Old 07-31-2022, 04:32 PM   #8
UPS Driver
UPS Driver's Avatar
Changing to 12-volts is mostly a matter of dealing with the coil and all the light bulbs. The horn fields can easily be rewound for 12-volts if needed. It's just more work to get it where 6-volts could still do the job.
Thank you I will try and trace it down this week my thinking is why not go ahead and switch to a 12 volt system if I have to mess with the 6 volt much?
Old 07-31-2022, 05:02 PM   #9
gdmn852
gdmn852's Avatar
Hello, 6 volt systems work well with the proper large battery cables, usually what happens is that they are replaced with small cables available from car parts stores, the small cables increase current draw when starting causing start problems. You will have stock 6 volt bulbs as not common anymore.The Roadster has an alternator on in , will charge to about 15 amps after starting then tapers back to only a few amps once on the road. On the steering gear, before taking it apart, try to adjust it ,sometimes you can adjust some of the play out , also check the kingpins and steering arm balls for roundness .
gdmn852 is offline   Reply With Quote
Old 07-31-2022, 05:12 PM   #10
UPS Driver
UPS Driver's Avatar
That’s what I’m checking on the ground strap is VERY old the negative side however doesn’t seem very heavy but has a brass end so not sure
Old 07-31-2022, 05:14 PM   #11
UPS Driver
UPS Driver's Avatar
I’m actually tempted to get everything together to make them from welding cables it’s not hard. We did it on my father’s 49 Chevy pickup
Old 07-31-2022, 07:42 PM   #12
Bill G
Bill G's Avatar
If the car sat for a long period of time, the alternator may have lost its residual magnetism and its ability to self excite. Easy fix. Take the rubber plug off the alternator and while running momentarily flash pin #1 to ground. If it has lost its magnetism, that's all it should take. That is the instruction I received from NuRex after mine sat for a year while I was restoring.
Old 07-31-2022, 07:45 PM   #13
UPS Driver
UPS Driver's Avatar
Thank YOU! I will try this tomorrow morning !
Old 08-01-2022, 04:50 PM   #14
Joe K
Joe K's Avatar
Steering boxes marked "Gemmer" are generally of a variant all by themselves. Parts are not made for these, but parts aimed at the later Gemmer design marked A-3550-C on the side CAN be used on the earlier Gemmer marked housings. Caviet - one must replace ALL parts within the Gemmer housing as in Worm, bearings both upper and lower, and races upper and lower.
This generally involves pressing off and pressing on the worm on the steering wheel shaft which some have had issues with (there are mechanical "dodges" for this.) One HAS to be sure the worm remains "concentric" with the shaft and "post press straightening" may be required of the steering wheel shaft.
Some have critiqued the use of a needle bearing conversion for the sector housing. The fault being that the side thrust of the sector shaft in the housing is considerable and the bearing essentially "non-rotating" - the needles wear "humps" into the shaft leading to "lumpy" steering.
Comment from another local hobbyist of my acquaintance indicates he has gone back to bushing and sector replacement done "The KRW Way" to include use of a reamer/hone to yield the tightest fit possible on the shaft. Perhaps not as long lived as a properly adapted needle bearing assembly but a repeatable repair once you have the technique down.
Joe K
Shudda kept the horse.
Old 08-01-2022, 06:40 PM   #15
UPS Driver
UPS Driver's Avatar
Joe K
I’m usually the guy that has it “parts aren’t available “ so just checking
Old 08-01-2022, 08:57 PM   #16
Joe K
Joe K's Avatar
Who was the WWII US General who claimed he was fated to fight his battles at the juncture of two maps?
Joe K
Old 08-02-2022, 07:20 PM   #17
UPS Driver
UPS Driver's Avatar
This worked perfectly thank you all!!
