Old 06-25-2022, 09:07 PM   #1
jeepguy1948
Default Hydraulic throw out bearing
Has anybody used a hydraulic throw out bearing in their model A?
jeepguy1948 is offline   Reply With Quote
Old 06-25-2022, 11:30 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Hydraulic throw out bearing
Why?
I definitely would not want to complicate things.
The Model A Throw out bearing works just fine as it is.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 06-26-2022, 01:13 AM   #3
Chris Haynes
Chris Haynes's Avatar
What is a hydraulic throw out bearing?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-26-2022, 05:55 AM   #4
Patrick L.
Patrick L.'s Avatar
I think he means hydraulic clutch linkage.
Old 06-26-2022, 09:41 AM   #5
old ugly
old ugly's Avatar
a hydraulic throw out bearing would probably work just fine.
if there is a need for it. maybe building a low speedster that the peddles have to be relocated or some sort of different application. but for the peddles in the stock location the original style work quite well.
are you building something weird? what is it?
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 06-26-2022, 09:50 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
I have not used a hydraulic throwout bearing in a Model A but I did use one in a '38 PU with an engine transplant, a '57 T-Bird Y-Block of course.
Simplified the clutch setup hugely in this installation as the mechanical clutch linkage wanted to interfere with everything and there wasn't enough room for a slave cylinder.
Old 06-26-2022, 10:07 AM   #7
Bob C
Here's a picture.
File Type: jpg Screen Shot 2022-06-26 at 8.05.32 AM.jpg (10.1 KB, 39 views)
Old 06-26-2022, 10:13 AM   #8
Y-Blockhead
Originally Posted by CWPASADENA View Post
Why?
My opinion,
Chris W.
It would make it easier to depress the clutch for someone who has leg issues. I don't know if that is the reason the OP asked the question tho.
Old 06-26-2022, 10:16 AM   #9
Patrick L.
Patrick L.'s Avatar
Originally Posted by Bob C View Post
Here's a picture.
OH OK.
As Emily Litella would say, "never mind".
Old 06-26-2022, 10:19 AM   #10
katy
katy's Avatar
Where ya going to find one to fit?
Old 06-26-2022, 01:01 PM   #11
old ugly
old ugly's Avatar
he shouldn't have too much of an issue finding one, most newer vehicles use them.
maybe 3/4 truck
the bearing retainer snout diameter is the first thing to fit.
old ugly
Old 06-26-2022, 04:04 PM   #12
Pete
Yes, a couple of them. They work good with a T5.
Old 06-26-2022, 04:48 PM   #13
nkaminar
nkaminar's Avatar
Bob C, You are making me feel old. The hydraulic clutches I am familiar with use a master cylinder and a slave cylinder outside the bell housing. It basically just replaces the mechanical linkage. Cannot remember the last one I worked on, maybe in the 50's or 60's.
Old 06-26-2022, 07:52 PM   #14
Synchro909
Synchro909's Avatar
IMO, there is nothing wrong with Henry's setup, even for those with leg strength issues. Since we have to modify the arm on the lower shaft anyway (for RHD), I make it a bit longer so that the pedal pressure is less. I wouldn't bother with hydraulics when something simpler will do the job just as well.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 06-26-2022, 11:48 PM   #15
jeepguy1948
I agree, there is nothing wrong with Henry's set up unless it's in the way (as was suggested above). This was largely a hypothetical question, something to file away for possible future use. I only recently became aware the such a thing existed. For reasons I don't have space or time to get into here, I was investigating a hydraulic clutch but quickly realized that there was not a reasonable way to deal with the slave cylinder. Just to remind everybody, it's my car I can do what I want to with it and I don't have to justify it with anybody (with the possible exception of my wife).
Old 06-26-2022, 11:48 PM   #16
jeepguy1948
To those of you that answered my question, Thank You!
Old 06-27-2022, 11:30 PM   #17
CWPASADENA
CWPASADENA's Avatar
I agree,
If your name is on the registration, then you are authorized to do with your car what you want to.
Others, including me, may have our own opinions but in the end, it is your call.
Chris W.
Old 06-28-2022, 10:53 AM   #18
gdmn852
gdmn852's Avatar
Hello, many foreign cars I owned have hydraulic clutch setup from factory , MG , Porsche, Subaru,probably needed due to lack of space and that’s just how they are built .Didn’t really see a big difference between the two.still have to have some free play to keep from throw out bearing from riding clutch. I could see someone mounting one for a heavy loaded pressure plate, a friend of mine has a muscle car that needs it can hardly depress clutch, not that much fun to drive in heavy traffic.
gdmn852 is offline   Reply With Quote
Old 06-28-2022, 11:05 AM   #19
katy
katy's Avatar
If one has a "hydraulic throw out bearing" and needs to replace the clutch, the throw out bearing should be replaced at the same time. Don't ask.
Old 07-04-2022, 10:39 AM   #20
jeepguy1948
Pete, thanks for he positive response. I would think that the same one you used for the T5 would work on the A transmission, they have the same O.D. don't they?
Don
