Old 06-14-2022, 03:51 PM   #1
Lamar Wadsworth
Lamar Wadsworth's Avatar
Default Rear exhaust manifold bolts
Is there a trick for getting a wrench on the exhaust manifold bolts closest to the firewall on a '55 Y-block? The rest of the exhaust manifold bolts are no problem, but the only wrench I can get on it is a box end, and there's not enough to swing a box end more than a few degrees before it hits stuff. I can't get a 3/8 drive 9/16" socket in there and there's no straight shot at the bolt to get in with a ratchet and extension. Is there something I'm missing?
Lamar Wadsworth is offline   Reply With Quote
Old 06-14-2022, 06:08 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: Rear exhaust manifold bolts
I have often used a 9/16" offset 12-point box end wrench. You can both tighten the bolt and loosen the bolt after it had been tight, but my wrench is fairly short, which is good because you have the ability to turn the hex head more in this tight space.
I also have a 9/16, 12-point curved handle wrench that I have used for this bolt too, but the offset wrench is more efficient and removes the bolt faster.
Sorry, I don't have photos of the two wrenches.
Old 06-14-2022, 07:40 PM   #3
paul2748
paul2748's Avatar
They make "shorty" wrenches which will help with the swing. I recently changed the manifolds on my Tbird and 54 - on the left side I could use a socket. On the Tbird, I went underneath to tighten the right with a standard box wrench. Can't remember what I used on the 54 right side
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-14-2022, 08:08 PM   #4
KULTULZ
KULTULZ's Avatar
Arrow Re: Rear exhaust manifold bolts
- ford special service tool -
File Type: jpg EXHAUST MANIFOLD WRENCH - Snap- On - S-8666 _1.jpg (50.8 KB, 39 views)
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-14-2022, 08:24 PM   #5
Lamar Wadsworth
Thanks!
Old 06-17-2022, 08:04 AM   #6
Ole Don
Ole Don's Avatar
Swap meet shorty wrench set is the answer. I use them so often I wonder how I ever got along without them.
Ole Don is offline   Reply With Quote
Old 06-26-2022, 06:00 PM   #7
Gene F
Gene F's Avatar
Hmmmm, my Dad has a manifold wrench in his tool box. I have never seen one used.
