Old 08-04-2025, 05:30 PM   #1
whatdoyouwant
Default 1955 ford 272
Ever since I rebuilt my car in 1990. When I wind up the engine prior to shifting from first to second or from second to third, I get a backfire and really no power. Once I hit highway speed and back out of the throttle, it runs great. I have done all the tune up many times and changed the cam shaft , another new timing chain, and even ground the valves on another set of heads and installed. I read somewhere that maybe the carbon wire are not putting enough spark to the plugs, and that solid copper core are better. One other thing I was thinking was, would weak valve springs cause this kind of reaction.
any help or ideas would be great.
whatdoyouwant is offline   Reply With Quote
Old 08-08-2025, 08:22 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: 1955 ford 272
Vacuum leak? Cracked dist cap?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-09-2025, 02:40 PM   #3
Oldgearz
Maybe something with the distributor advance isn't working right. Your description sounds like it doesn't like rapid full throttle. Also check accelerator pump in carb?
Oldgearz is offline   Reply With Quote
Old 08-09-2025, 06:07 PM   #4
miker98038
miker98038's Avatar
Just how tight are you winding it up? Do you know what valve float feels and sounds like?
miker98038 is offline   Reply With Quote
Old 08-10-2025, 12:07 AM   #5
dmsfrr
dmsfrr's Avatar
Originally Posted by whatdoyouwant View Post
... When I wind up the engine prior to shifting from first to second or from second to third, I get a backfire and really no power. Once I hit highway speed and back out of the throttle, it runs great. ...
Originally Posted by Oldgearz View Post
Maybe something with the distributor advance isn't working right. Your description sounds like it doesn't like rapid full throttle. ...
The timing advance in '56 and earlier Y-block Loadomatic distributors is controlled only by a very low vacuum signal from a year matching original carburetor. They do not have any mechanical timing advance. Photo example below.
If the carburetor isn't original, the vacuum canister has failed or the hardware of the points mounting / advance plate is stuck... you'll get no timing advance and it won't run quite right at more than approx half throttle.
Similar internal hardware problems apply to improved '57+ distributors but a little less often.
Check that the timing advance at higher rpm's goes at least 10° beyond the initial setting at idle.
Also check the gap or dwell settings of the points are at correct specs before setting the timing.
https://www.ctci.org/gilsgarage/crac...aust-manifold/
https://www.ctci.org/vacuum-advance-mechanisms/
File Type: jpg 54 55 56 loadomatic, 'flat' dist rotor index.jpg (63.7 KB, 59 views)
Old 08-10-2025, 01:41 AM   #6
mercman from oz
mercman from oz's Avatar
Old 08-10-2025, 08:26 AM   #7
whatdoyouwant
Thanks for the responses. I have the correct dist and carb for the car. I have determined with a timing light that there is advance when opening the throttle. I have new points, condenser, dist cap and new carbon wires. I am winding it up to accelerate and no, I don't know how valve float feels. That is why I was thinking maybe I have weak springs. I have new springs coming and will try to install them without removing heads. I guess we will see.
Old 08-10-2025, 10:12 AM   #8
wellcraft17
What carb, size of main jets, and power valve do you have? Sounds to me like you maybe running out of fuel at a higher RPM.
wellcraft17 is offline   Reply With Quote
