I have this black plastic thing-a-ma-bob doohicky that I have no idea what it is or where it goes. The rats found it and decided it would be a good piece of plastic to gnaw on. Here is a pic of the Ford engineering number. I looked on the internet for this nuber but drew blanks. Any one have any idea what this is based on the engineering number (C8AB-62130A46-A)? The car is a 1968 Galaxie 500, and this was on the rear floorboard when I opened to door. Pretty sure it wasn't laying there when I parked the car 8 years ago. I'm thinking the rats found it and moved it to the floorboard.
![]() Last edited by Stephenorf; 05-28-2022 at 02:18 PM. |
Is it some sort of coil spring isolator? I don't know
The "C8..." I believe means 1968, so that would apply to your car. |
It would help to post a photo of the entire part, not just the number.
ok, it seems to be at least 1/2 gone. But here are some pics of whats left. I'm wondering if it might be some wire shield from under the dash, like maybe near the steering column. It seems rodents were chewing on wires on the driver's side near the firewall.
Possibly a seal around the steering column at the firewall????
I wonder if there is a way to positively identify the part using the engineering number?
Yes, but you would need the correct period text. It is called a MASTER CROSS REFERENCE LIST. I only have reference up to the 1964 model year.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
#9 | |
![]() Quote:
Could it be a plastic dust shield housing that goes around
the gas pipe filler neck to the quarter panel... .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. ![]() |
Part # is C8AZ-62130A46-A "Retainer, Carpet to Steering Column".
That makes sense. Looks like some rats chewed their way from the engine compartment to the interior of the car, or from the interior to the engine compartment via the firewall at the steering column hole.
