Old 04-23-2022, 11:31 AM   #1
GerryAllen
Default Spark Plug replacement
Guys & Gals, how often ie. many miles do you replace your spark plugs? As a rough rule if thumb how often do you pull the plugs and clean them. I understand the cleaning of the plugs is dependent on a number of factors.
Gerry Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 04-23-2022, 12:52 PM   #2
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Default Re: Spark Plug replacement
If it's running good, I leave them alone. I don't clean or re-gap them unless they are fouled or running poorly.
Ivan in southeast va. is offline   Reply With Quote
Old 04-23-2022, 01:01 PM   #3
Brentwood Bob
3X plugs? I am not impressed with metric modern plugs, but who am I?
I remember the sand blast plug cleaner.
Brentwood Bob is offline   Reply With Quote
Old 04-23-2022, 01:07 PM   #4
GerryAllen
Bob. the question was about every how many miles do you replace your plugs. I used use the sand blast plug cleaners as well :~)
Old 04-23-2022, 01:28 PM   #5
Patrick L.
Patrick L.'s Avatar
The old rule of thumb was about 10K miles for old points ignition. But, thats an old rule, they'll go much farther
The Autolite 3076s have been in mine about 30 yrs.
Old 04-23-2022, 09:28 PM   #6
Herb Concord Ca
Seeing as today we have lead free gas, plugs may outlast you. In new cars, some can reach 100,000 miles. In you Model A a long time!
Herb Concord Ca is offline   Reply With Quote
Old 04-24-2022, 08:41 PM   #7
30Murray
Gerry, spark plugs are like Apple pie. If they're golden brown they're just right. You should know that.
30Murray is offline   Reply With Quote
Old 04-24-2022, 09:45 PM   #8
J Franklin
J Franklin's Avatar
When you are pulling a fairly steep hill and start getting a miss it is time to look at the plugs.
Old 04-24-2022, 09:59 PM   #9
Dino's A
Dino's A's Avatar
Sure, it can be time to clean or replace. BUT.......recently my 1943
Ford jeep was missing under a load and it turned out to be the
points were bad. Metal transfer to the point arm was the culprit.
I filed the points clean, to diagnose the problem, and ordered a set
of points. The condenser causes the transfer so definitely changed that.
Dino's A is offline   Reply With Quote
Old 04-24-2022, 10:57 PM   #10
CWPASADENA
CWPASADENA's Avatar
I have 18K miles on the 3X reproduction plugs in my Tudor. I have yet to clean them, they still are just fine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-25-2022, 11:01 AM   #11
J Franklin
J Franklin's Avatar
The 3X plugs seem to run very clean in my car.
Old 04-25-2022, 07:19 PM   #12
chrs1961815
chrs1961815's Avatar
Don't mean to hijack this thread, but should you replace plugs after a head gasket leak? I am in this situation right now.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-25-2022, 09:09 PM   #13
J Franklin
J Franklin's Avatar
What would be the need? Plugs should be replaced when they no longer do their job.
Old 04-25-2022, 09:48 PM   #14
chrs1961815
Don't know if antifreeze does any harm to the electrode or not.
Old 04-25-2022, 11:08 PM   #15
CWPASADENA
CWPASADENA's Avatar
The plugs should be fine after a head gasket leak. Anti-freeze should not harm them.
Chris W.
Old 04-27-2022, 10:22 AM   #16
Tosti36
If the engine is running fine I don't touch them. You might want to just remove and get a reading on how the engine is running.
Tosti36 is offline   Reply With Quote
Old 04-28-2022, 11:22 AM   #17
katy
katy's Avatar
How is the engine going to run if he removes the spark plugs?
Old 04-28-2022, 11:31 AM   #18
J Franklin
J Franklin's Avatar
Maybe take one out at a time?
Old 04-28-2022, 03:27 PM   #19
woofa.express
woofa.express's Avatar
I agree. During my childhood I learned a useful saying. "Let sleeping dogs lie".
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
