Old 04-24-2022, 02:15 PM   #1
Gwill65074
Gwill65074's Avatar
Default Gemmer steering box
My 1930 Tudor has a Gemmer steering box with the letter F on the engine side. I believe it is a two tooth and would adjust the same as Ford's two tooth. My question is, the box does not have a plug to fill it through, instead it has a grease cup on top. Am I wrong in thinking this only uses grease to lube the box? Thanks.
Gwill65074 is offline   Reply With Quote
Old 04-24-2022, 02:45 PM   #2
lotsagas4u
Default Re: Gemmer steering box
Put John Deere corn head grease in it, it was originally filled with heavy gear oil, but leaked all the time.
lotsagas4u is offline   Reply With Quote
Old 04-24-2022, 03:01 PM   #3
Gwill65074
Gwill65074's Avatar
Thank you very much.
Old 04-24-2022, 06:28 PM   #4
Patrick L.
Patrick L.'s Avatar
The grease fitting was put in quite often. But, then, folks would pump grease into it. As a kid [ Ford garage] we did it but used a grease gun filled with the heavy oil.
Old 04-24-2022, 07:20 PM   #5
Gwill65074
Gwill65074's Avatar
Thank you
Old 04-24-2022, 09:56 PM   #6
redmodelt
redmodelt's Avatar
The proper lube for the gear box would be 600W or its equivalent, same as transmission or rear end. No grease. Grease does not flow where it needs to go. There are some Penrite products that should work. John Deere Corn Head grease, has different flow characteristic then just grease.
Old 04-25-2022, 07:54 AM   #7
Gwill65074
Gwill65074's Avatar
Thanks, I've ordered some 600w and I'll try to get as much grease out of it as I can and replace it with the 600. Thanks again guys for helping me.
Old 04-25-2022, 12:17 PM   #8
rotorwrench
rotorwrench's Avatar
The "F" cast marking indicates that the unit was made by Ford since both Ford & Gemmer made them. Gemmer made units had the patent markings on them until later in 1930 or so when they had no markings at all. The Gemmer boxes will detach from the column and have a clamp there to secure the two together. The 7-tooth units had the box integral with the column and can not be removed.
Old 04-25-2022, 01:09 PM   #9
Gwill65074
Gwill65074's Avatar
Thank you. I pulled the grease cap and fitting of today and got a lot of the grease out of the box. Afterwards I put about 1/2 oz. of 600 in it to see if it is going to leak out later today. Thanks again for the information.
Old 04-25-2022, 01:52 PM   #10
Patrick L.
Patrick L.'s Avatar
I think thats the easiest thing to do.
Just dig out what you can and add the oil. Don't worry though, it'll leak.
Old 04-25-2022, 02:31 PM   #11
Gwill65074
Gwill65074's Avatar
awesome
Old 04-25-2022, 04:29 PM   #12
lotsagas4u
And that's why they use corn head grease
Old 04-25-2022, 06:08 PM   #13
rotorwrench
The lower bearing plate with the tube on it will sometimes crack at the bottom of the tube & leak. The lower housing seal under the bellville washer can also leak due to deterioration. Worn out sector shaft bushings will leak too.
A person can modify the sector housing for needle bearings and a lip seal which may slow the oil loss a good bit. There are still a few areas that normally seep and can be dealt with during overhaul but over time may start seeping again.
Old 04-25-2022, 07:21 PM   #14
Gwill65074
Gwill65074's Avatar
Thank you
Old 04-26-2022, 10:17 AM   #15
Patrick L.
Patrick L.'s Avatar
600W works out to between a 180 and 240 weight oil.
Ford went to 140 before I came along and we always had a drum of it hanging around. I could never notice a difference between any of them.
I think the A now has 250 in it as I didn't like any of the 600W available as it foamed too much to suit me.
Old 04-26-2022, 12:00 PM   #16
Gwill65074
Gwill65074's Avatar
Thanks Patrick
