Old 03-27-2022, 05:45 PM   #1
YoDon1954
Default Tracing Wires
Hello! Can anyone recommend a good electric probe to trace wires in my '52 Ford? I don't want them that connects to the car's battery. Thanks!
YoDon1954 is offline   Reply With Quote
Old 03-27-2022, 06:43 PM   #2
Bob C
Default Re: Tracing Wires
Power Probe is the way to go. https://www.amazon.com/s?k=power+pro...f=nb_sb_noss_1
Old 03-27-2022, 07:08 PM   #3
aussie merc
aussie merc's Avatar
power probes work but you can make your own all you need is 1 a nine volt battery 2 a couple of clips 3 a roll of 5 amp wire 4 a pizo buzzer hook one end to the wire you want to trace and go looking for the other end when you find it should buzzzz
aussie merc is offline   Reply With Quote
Old 03-28-2022, 11:12 AM   #4
YoDon1954
Thanks!
Old 03-28-2022, 01:08 PM   #5
51woodie
51woodie's Avatar
Info for a pizo buzzer.
51woodie is offline   Reply With Quote
Old 03-28-2022, 01:35 PM   #6
rotorwrench
rotorwrench's Avatar
I use a multi-meter with a selection of different probe tips. I use the Ohms meter mostly since it will tell you if the resistance is too high or not. High resistance in a 6-volts system is not good.
